| has pooped his pants | Variator Info For All You Vari-Haters! If you've got a variator in your Stilo and you're wondering if it's got an issue with it, remember, it might not actually be the variator itself, it could be the variator actuator. Both these items fall under the error code P1653, so the fault could lie with either... one is easy to test though, here's how To rule out the variator actuator as being the fault rahter than the variator itself, take off your engine coil cover and get your trusty multimeter out... What you're trying to do is to test the variator solenoid, and it's easy to diagnose, just put your multimeter across the 2 terminals of the solenoid (the blobs on the top, not the plug connectors) and check for continuity, if there's none (eg. you've got some resistance there) then undo the 2 philips screws on the top of it and remove the cap (pull it off, don't twist), connect the multimeter to the 2 spikes on the solenoid and check for continuity again, I bet you get it this time. if you do then it's the cap at fault, what you need to do is drop little balls of solder into the 2 holes for the spikes in the cap and then fit it back on, then you should have your continuity back accross the plug terminals. Once you've done this, then you can be reasonably sure that your actuator should be okay and the problem lies with the variator itself... bad luck ![]() If you didn't have continuity across the cap and the actuator pins, then the actuator is probably at fault and you'll need to get it replaced. At least it's cheaper than the variator though! ![]() I hope this helps anyone who's concerned about their variator
__________________ ![]() 02 Fiat Stilo Abarth (5dr) Navy Blue, Cream Full Leather Interior, 17" Anthracite Alloys with Goodyear Eagle F1 Asymmetrics, Schumi GP Prodrive Suspension (Eibach Springs and Bilstein Dampers), Denso Iridiums, EBC RedStuff Pads. To Do: OMP Strutbrace, BMC CDA, Cat-back Exhaust | ||
| Whaddya mean too old? | Re: Variator Info For All You Vari-Haters! Good stuff Greggers. That would be very useful in the Stilo guides for those with variators
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #3 | |||
| has pooped his pants | Re: Variator Info For All You Vari-Haters!
It's quite interesting, after seeing the P1653 code looged in my car after doing the mod to my code reader, it got me thinking, "could this be the cause of my kangarooing?" ![]() After carrying out the work I described here, I've taken the car out for a quick drive and I made sure the car didn't warm up before I set off and guess what?... no kangarooing!! ![]() I'm going to keep an eye on it and see how it goes over the next few cold starts but fingers crossed! It'd be interesting to see what other Selespeed owners find if they carry out the same checks that I did and to see if it cures their kangarooing... worth a try!
__________________ ![]() 02 Fiat Stilo Abarth (5dr) Navy Blue, Cream Full Leather Interior, 17" Anthracite Alloys with Goodyear Eagle F1 Asymmetrics, Schumi GP Prodrive Suspension (Eibach Springs and Bilstein Dampers), Denso Iridiums, EBC RedStuff Pads. To Do: OMP Strutbrace, BMC CDA, Cat-back Exhaust | |||
| Tags |
| kangaroo, variator |
| | mafia11 | Punto | 4 | 24-06-2008 14:49 |
| | JOFF | Marea | 2 | 16-06-2006 13:03 |
| A thread for Paul and all the other Bush haters | jamie86 | Leisure Lounge | 20 | 17-11-2004 15:26 |
| | Ems | Punto | 1 | 01-11-2004 20:31 |
| Fiat Haters | DaveP | Leisure Lounge | 25 | 12-08-2004 19:52 |
