The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 27-08-2008   #1
Trader Rating: (0)
Stereo modification
Is it possible to fit the steering wheel with stereo controls from another Stilo to my Multiwagon, is the wiring already in the car, what bits do I need if this can be done, can it be done at home easily or is it an auto electrician job. Has this job been done before, any advice welcome thanks.
sunbeamsupreme is offline
Old 27-08-2008   #2
Trader Rating: (0)
Netherlands
Re: Stereo modification
this can be done but you will have to fit another coil spring behind the steering wheel , change the wiring from the coilspring (two extra can-wires and a +12v wire) - it can be done yourself if you are a handyman , otherwise leave this to a car-electrician....
see http://fk2000.stilo.info/mufu.htm
yellowstilo is offline
Old 27-08-2008   #3
Trader Rating: (0)
Thanks, is the coil spring refered to as a clock spring in the workshop manual and when I get a steering wheel I will need these bits too. It is also a pity those instructions are in German as they could be just what I need.
Old 28-08-2008   #4
Trader Rating: (0)
Netherlands
yes i meant clock spring (i'm Dutch so sometimes it's difficult to find the proper description...) - the pictures on the site are pretty well self-explanatory , you have to connect three extra wires on a (Abarth) clockspring - if you buy a used one pay attention to keep it aligned in it's original position because it needs a certain slack to both sides.
I did my Connect Nav+ and steering wheel modification this way and it works 100%!
Old 29-08-2008   #5
Trader Rating: (0)
Thanks Yellowstilo I shall now look into this but do I have to use an Abarth clockspring or will any stilo with one of these steering wheels be OK.
Old 29-08-2008   #6
Trader Rating: (0)
Netherlands
with the Abarth clockspring you have all functions for certain - a clockspring from another version will also work if it comes from a car with steering wheel buttons - ás far as i know a low- and high version of the CAN-node inside the steering wheel exist (only radio control or all CN+ options)
Old 30-08-2008   #7
Trader Rating: (0)
I am hoping to get all the bits from a breakers yard so I will get the wheel and clockspring from the same car if not I may get the wheel and buy an arbarth spring from Fiat, also what is this CN+ all about. Thanks.
(S) First modification alainax Cinquecento / Seicento 14 30-04-2006 20:39
Modification maximus14 Panda (New) 4 12-04-2006 16:40
(S) dash modification? hazza Cinquecento / Seicento 28 23-12-2005 19:39
(S) Help on Modification MadMatt6633 Punto 3 26-11-2005 14:44
(T) Starting engine whilst stereo playing disables stereo superleccy Stilo 5 19-09-2004 14:41
