Right it goes from bad to worse!,
did a fault code scan with no results today, but onething that did catch my eye was, as with most of these fault code readers, the dash flashes loose connection once, with the asr/esp lights lighting up, this is identical to whats happening at 4000-5000rpm,
is this showing a communication loss between the ecu and dash??
what ive done:
all earths check
fan connection check
clocks out and check
all relays and fuses out under bonnet and checked
all coils out and checked
new battery
voltage checked 12.8/14.1
new spark plugs,
crank sensor check
brake switch replaced
d4 and all connectors close, all cleaned up and checked
ecu connectors cleaned,
abs/asr connector block cleaned
im so at the end of my tether at the mo, i'd glady torch the f****king car, 5 nights up to now fault checking and the car is in bits!,
sadly this has really thrown my liking of fiats, all i want to drive it trouble free! is it too much to ask??
since june its had nearly £1500 put into it, how much further do i keep going?? im at a loss as im not in any financial situation to get another car either!
right feel a bit better now thats off my chest
