The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 23-07-2008   #1
Trader Rating: (0)
Smile Engine Warning AFTER cleaning inlet control valve?
Hey guys, (and dolls)
First of all, what a damn fine forum you have here and you're so blooming helpful it brings a tear to my eye!
SO, my stilo was idling very erraticly and also stalling a fair bit, i cleaned the inlet control valve and immediatley the engine warning light came on! ALTHOUGH, the vehicle seems to idle perfectly now, i was wondering if the fact i unplugged the valve could have caused it BUT surely it would be ok once its plugged back in? Apart from the idle all was fine previously.
Please help, i hate having to use the extra energy to press the mode button to silence and hide the error! It take too much effort!
Thanks in advance!
ICOD is offline
Old 23-07-2008   #2
Trader Rating: (0)
Netherlands
Re: Engine Warning AFTER cleaning inlet control valve?
i guess this indicates the throttle body needs a throttle relearn procedure - it is somewhere on this forum , please use the search button to find it...
yellowstilo is offline
Old 23-07-2008   #3
Brain freeze
LoBsTeR's Avatar
Trader Rating: (0)
LoBsTeR has donated! United Kingdom
How did you clean the valve?
Stilo JTD 115 3dr Dynamic 2002 with Skyroof, 16" Alloys, in Pitti Blue. No mods........yet
LoBsTeR is offline
Old 26-07-2008   #4
Trader Rating: (0)
Hi, thanks for the replies,
I went on a 150mile trip yesterday BUT by the time i got to 30 miles the light went out so im happy now!!!
I think it may have relearned it self!
LOBSTER, i removed the whole body and cleaned it with WD40. I was lookin at one of the other guys guides on here for stilo's that "hunt" when idling and low power, ALTHOUGH he said clean whilst its fitted i decided to remove. HOWEVER---The fact he has helped me fault find a problem the dealers couldnt i am very impressed with!
You guys are brilliant!
Keep it up!
<iframe src="http://gamercard.xbox.com/CSI%20ICOD.card" scrolling="no" frameBorder="0" height="140" width="204"></iframe>
ICOD is offline
Old 28-07-2008   #5
Stilatos's Avatar
Trader Rating: (0)
Greece
Guys dont use wd-40 they sell cheap sprays specifically designed for this. Using wd-40 might make things worse since it will coat the whole inlet manifold with oil. Just go get a carburetor/air inlet cleaner (make sure its catalyst friendly so you dont destroy your catalytic converter) Make sure you have a friend keeping the revs high about 3,500 and spray the inside all aroundso you can get the guck out of the inlet manifold as well.
1.6 silver dynamic 3d with skywindow, Schumacher Look, Abarth Pedals,Brembo Brakes,Bilstein Eibach Suspension, Eagle F1 Tires, K&N Filter,Sport Steering Wheel,Sport Knob,3M tint.Philips New Vision Lights. Founder & Admin of the Greek Stilo club www.stiloclub.gr
Stilatos is offline
Old 28-07-2008   #6
Trader Rating: (0)
Cool Re: Engine Warning AFTER cleaning inlet control valve?
DUDE, you dont have the engine running when you clean it!
That would just suck the cloth out your hand!
I use wd40 to remove deposits of built up grime. It works better than carb cleaner. Carb cleaner usually evaporates too quickly!
WHOLE INLET MANIFOLD? you make it sound like we're cleaning the whole manifold? We are only using small amount to clean a ring around the butterfly! of the valve control body NOT the whole manifold!
Calm down mate, most people on here are experienced enough to know when to use and when not to use!
ICOD is offline
Tags
engine, idle, warning
(T) Cleaning Your Inlet Control Valve on an Abarth MPapps Stilo 13 3 Weeks Ago 08:49
(G) Inlet control valve mooshooh Stilo 4 04-04-2008 20:58
(G) Inlet control valve? mooshooh Stilo 0 04-04-2008 19:23
(G) idle control valve cleaning gigahr Punto 3 10-09-2006 18:56
