Evening peeps! Hope I'm doing the right thing by bringing up an old thread here - I think this one is most relevant...
I'm having a small issue with my JTD at the moment and very poor fuel consumption. I had some issues with performance about 3 months ago, which I resolved by cleaning the MAP and MAF sensors with carb cleaner, and replacing the very dirty EGR valve with a brand new one (which I'd cleaned before without any luck). Basically now the car is driving pretty well, apart from a slight flat spot when accelerating from stopped and reading very low average consumption - it's crept down consistantly from 45mpg to now 39.9mpg (reset counter a few times). Bearing in mind that 6 months ago this was 55-ish then not good! -
It's also chucking out a bit of gray-ish smoke on first few seconds whilst pulling away.
I took off and cleaned the intercooler hose (the bottom hose from intercooler to turbo, with two flexible hoses and one metal piece), and inspected this for damage, although no whistling noise as such. Noticed that it had started to cut into the plastic underbody liner where it passes into the engine bay, but it doesn't appear to have gone through yet (poor design for sure!). Checked along the hard plastic overboost tubing for any damage, and up towards the top of the engine, but can't see any gaping holes. I moved the valve up to the battery box last year, and wondered if it might have cracked it, but I can't find any strong-enough hosing to try replacing it with. Today I also tried running the car with the MAF sensor disconnected, thinking this might be the culprit, and it felt underpowered (as expected) but it poured black smoke out on acceleration and had even bigger turbo lag???
So... what to try? Should I blank off my (almost brand new) EGR valve tomorrow, try cleaning the overboost valve or just run it to FIAT!? Any suggestions would be brilliant! BTW I've used the search feature til I'm having nightmares about it lol. Cheers :slayer:
