| stilo abarth 04 dashboard Hi can anyone help? Problem started when my temp display went off the dash comp, then thewindows would not open with door control, followed by mirror controls on door panel, every time i went out in my car something new went wrong. Now none of the dials work and the lights stay on! I took it to my local garage, who fixed the window and mirror controls but not the dials on the comp. He says I should take it to the fiat garage and I might need a whole new dash !! Has anyone had this problem? If so how much does it cost? PLLLEASE Help!!![]()
| | #2 | |||
| 5 pots rule!! | Re: stilo abarth 04 dashboard
__________________ Previous Car : 2002 Mk2 Punto Active Sport in Broom Yellow Everday Car : 1999 Mk1 Punto Sporting in Silver Weekend Toy : Stilo Schumacher GP | |||
| | #3 | ||
| Re: stilo abarth 04 dashboard i guess the 2004 Abarth dash has the monochrome lcd display inside, not the colour display? In that case it is possible to fit a (second-hand/scrapyard) cluster of another (non-Abarth) Stilo , change the silver/white dials , have a Proxy alignment procedure perfomed by your local Fiat dealer and have the mileage adjusted upward to the original mileage. Beware to buy a cluster with the same or less miles on it as it can't be adjusted downward (legally). First i would check your battery voltage at key-off , key on and running - low battery voltage can cause all kind of strange failures....
| The following user says "Thank You!" to yellowstilo for this useful post: | ||
andy monk (17-07-2008) | ||
| | #4 | ||
| Re: stilo abarth 04 dashboard You have too many faults all happening together to be each part causing the fault. It will be something common to all these parts, like a corroded earth point/ connector somewhere.
__________________ WANTED: Faulty Connect Nav+ for parts, to fix mine. | |||
| The following user says "Thank You!" to john55 for this useful post: | ||
| | #5 | ||
| Re: stilo abarth 04 dashboard Thanks for your help, its booked in to our local fiat garage on monday for a quote for the work that needs doin. Will post the quote and the job list when I get it.
| | #6 | ||
| Re: stilo abarth 04 dashboard Hi Andy - did your dashboard problem get resolved? Sounds similar to the problem on my husband's Stilo so I'd be interested to hear how they sorted it so I can prepare for a big bill ![]()
| For Sale: stilo abarth white dials with screen (FIAT Stilo Parts) | stripey stilo | For Sale / Wanted | 0 | 01-06-2008 08:48 |
| Stilo Upper Dashboard | Muffit | Stilo > Technical | 1 | 08-02-2007 19:44 |
| stilo dashboard | amanda aird | Stilo > Technical | 16 | 04-02-2007 14:38 |
| Stilo Dashboard died? | STONKING | Stilo > Technical | 12 | 31-01-2007 10:05 |
| Abarth dashboard in other Stilo model? | Karateka_GR | Stilo > Technical | 121 | 20-06-2006 16:04 |
