The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 16-07-2008   #1
Trader Rating: (0)
New 18's - need to firm up the ride - Help!!
I noticed a lot of you have slammed on some 18's and still mangaged to lower the stilo.
I'm after some firmer spings and i thing the Eibach Pros with a 30mm drop will be best (don't want it to look too slammed)
Will the 30mm drop still leave enough room for the 18's (running 225/40/18 tyres on a 54reg 1.6 active sport by the way). Has anyone had any problems etc??
Cheers guys
Stilo 1.6 16V , FUll Abarth Kit , Shadow Chrome Wolfrace Spyders 18's ... Work in progress
Adz5156 is offline
Old 16-07-2008   #2
5 pots rule!!
red-devil's Avatar
Trader Rating: (0)
red-devil has donated! United Kingdom
Re: New 18's - need to firm up the ride - Help!!
Originally Posted by Adz5156 View Post
Cheers guys
they will be fine, iv got 18's lowered 50mm, no problems
Previous Car : 2002 Mk2 Punto Active Sport in Broom Yellow
Everday Car : 1999 Mk1 Punto Sporting in Silver
Weekend Toy : Stilo Schumacher GP
red-devil is offline
Old 16-07-2008   #3
has pooped his pants
Greggers's Avatar
Trader Rating: (0)
Greggers has donated! United Kingdom
What dampers you using Red?
02 Fiat Stilo Abarth Selespeed (5dr)
Navy Blue, Cream Full Leather Interior, 17" Razor Alloys, Denso Iridium Sparkplugs. Want: Eibach Pro Springs, Koni Dampers, Ragazzon/Supersprint Exhaust, EBC Red Stuff Pads and EBC Dimpled & Slotted Discs
Greggers is offline
Old 16-07-2008   #4
5 pots rule!!
red-devil's Avatar
Trader Rating: (0)
bilstein
Old 16-07-2008   #5
Low Rider..............
coyle's Avatar
Trader Rating: (0)
coyle has donated! United Kingdom
my mate had eibach prolines on 18's.
he had no problem at all..if anything.. i should have been lowered more
get your 100mm coilovers out
coyle is offline
Old 16-07-2008   #6
Greggers's Avatar
Trader Rating: (0)
bilstein
So you're running the Prodrive dampers then? Are you on the original Prodrive Eibach springs then as well?
Greggers is offline
Old 16-07-2008   #7
5 pots rule!!
red-devil's Avatar
Trader Rating: (0)
Yeah prodrive dampers, the prodrive springs were only 21 front and 17 at the back, im on the ultra low sport line kit that eibach dont do anymore, 50mm front 45 rear
Old 16-07-2008   #8
Trader Rating: (0)
hmm,
will the dampers need upgrading then if i'm to change the springs?
have seen a Eibach sportline kit 30mm drop rear and 45-50mm drop front that looks interesting. Are these any good?? (i'm not exactly going to be racing it round a track not yet anyway!) £120 delivered is that a good price too??
Cheers guys
Adz5156 is offline
Old 16-07-2008   #9
Greggers's Avatar
Trader Rating: (0)
Can I ask your advice? What do you reckon the Eibach Pro 30mm would be like on the OEM Abarth dampers? Would it be a crappy ride and handling choice? Would it be worse than the OEM springs with the OEM dampers?
Greggers is offline
Old 16-07-2008   #10
coyle's Avatar
Trader Rating: (0)
ive got the 50mm front 35mm rear eibach's.
they are very good, and im on standards shocks.
Im wanting to go lower though, so having coilovers
there is another lad on here, on 18's lowered 110mm on coilovers
coyle is offline
Old 16-07-2008   #11
coyle's Avatar
Trader Rating: (0)
would be better, not as soft as crap standard, lower centre of gravity, so less roll..
would slide abit more though..
thats my view of my oem shocks and eibach sportline springs
coyle is offline
Old 16-07-2008   #12
Trader Rating: (0)
Coyle,
Have you got a pic of the profile on the 50mm - 35mm drop, just curious as to what it looks like. Also how different are the Abarth OEM Shocks and the ones in my active sport?
Cheers mate
Adz5156 is offline
Old 16-07-2008   #13
Greggers's Avatar
Trader Rating: (0)
Coyle,
Cheers mate
I believe that they're totally different due to the extra weight of the 2.4 engine. The 2.4 shares the dampers of the 1.9 JTD 150 though... (and maybe the 115?)
I don't think they're cross compatible if that's what you're asking...
Greggers is offline
Old 16-07-2008   #14
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
hmm,
A lot of folk report good results with just Eibach -30mm springs alone (doesn't necessary apply to other makes mind you ) although most agree they wished they'd uprated the dampers at the same time
Go any lower without upgrading dampers and you'll almost certainly find your handling will be degraded over standard setup on anything other than perfect surfaces. Motorways and good 'A' roads should be fine but but as soon as you hit the windy stuff on a not so perfect surface then you'll be in real trouble. What you need to remember is you also lose the safety factor since if you do hit an unexpected obstacle on a tight curve on an otherwise good surface then you'll very likely lose grip and may not recover. In practice you just tend to drive slower to compensate
I discovered this when I dropped -35mm without bothering to upgrade dampers. The car, now back to standard, is much more assured
I should point out I don't drive on my brakes but for anyone who does then the standard setup is pretty dire.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
The following user says "Thank You!" to Argonought for this useful post:
Greggers (16-07-2008)
Old 16-07-2008   #15
coyle's Avatar
Trader Rating: (0)
Coyle,
Cheers mate
50mm front 35mm rear on eibach sportlines on my active sport
coyle is offline
vB code is On
18's Sc00bie Grande Punto > Styling 51 02-04-2008 13:57
Panda Removals firm spankysmagicpiano Panda (Classic) 7 31-08-2007 18:49
Firm Suspension??? duffman Stilo > Technical 0 10-02-2007 00:19
Rubbing on 18's scottie2065 Stilo > Styling 19 23-03-2006 11:10
Low and firm Lex Bodyshop 2 01-02-2004 20:01
