| | #17 | |||
| 5 pots rule!! | Re: New 18's - need to firm up the ride - Help!!
![]() ![]() bit of advice though, if you plan on going lower than 30mm, seriously consider uprating the dampers, the standard ones wouldnt last long on anything above 35mm, they will nearly be full compressed and going over bumps would eventually kill em
__________________ Previous Car : 2002 Mk2 Punto Active Sport in Broom Yellow Everday Car : 1999 Mk1 Punto Sporting in Silver Weekend Toy : Stilo Schumacher GP | |||
| The following user says "Thank You!" to red-devil for this useful post: | ||
Greggers (16-07-2008) | ||
| | #18 | |||
| has pooped his pants | Re: New 18's - need to firm up the ride - Help!!
You hit the nail on the head there... I want to improve the handling and feel of the car as I feel it deserves it but at the same time, I don't want to spend shed loads on making it happen. The Eibach Pro 30mm springs are what I'm after as the drop isn't too much and the cost is acceptable for the improvements. Dampers for the Abarth are few and far between and the Koni look like the weapon of choice but their cost is prohibitive for me. Being able to drop 30mm on the OEM dampers is my ideal choice... as long as it's actually worthwhile. From what you say, it sounds like it is Cheers dude!
__________________ ![]() 02 Fiat Stilo Abarth (5dr) Navy Blue, Cream Full Leather Interior, 17" Anthracite Alloys with Goodyear Eagle F1 Asymmetrics, Schumi GP Prodrive Suspension (Eibach Springs and Bilstein Dampers), Denso Iridiums, EBC RedStuff Pads. To Do: OMP Strutbrace, BMC CDA, Cat-back Exhaust Last edited by Greggers; 16-07-2008 at 18:38. Reason: Sh!te spelling | |||
| | #19 | |||
| It's about GO! not SHOW! | Re: New 18's - need to firm up the ride - Help!!
When you lower a car and hit a bump then the spring travel will be reduced compared to standard (but the same energy is absorbed by the suspension) Since you're using the same damper then it follows the damper absorbs less energy than in the standard setup and it's this excess energy remaining in the suspension which is the problem. The damper is still working on the rebound but by then it's too late since if you hit another bump then the energy just continues to build. You can easily feel this effect driving a lowered car (with oem dampers) on a bumpy road. The car actually feels like it's jumping all over the place The best way to prove this is to whip the car down to your local garage and get uprated dampers fitted (or inversely put standard springs back on as I did) and then immediately drive on the same bumpy road again. I guarantee you'll be amazed at the difference. Your Prodrive dampers should be perfectly matched to your springs so your Schu should feel nicely glued to the tarmac Importance of matching shocks to springs can't be overstretched enough ![]() Greggers, Have you considered Eibach -30mm combined with a damper upgrade on the front only - shouldn't cost that much more
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic Last edited by Argonought; 16-07-2008 at 19:39. | |||
| | #20 | |||
__________________ ![]() 02 Fiat Stilo Abarth (5dr) Navy Blue, Cream Full Leather Interior, 17" Anthracite Alloys with Goodyear Eagle F1 Asymmetrics, Schumi GP Prodrive Suspension (Eibach Springs and Bilstein Dampers), Denso Iridiums, EBC RedStuff Pads. To Do: OMP Strutbrace, BMC CDA, Cat-back Exhaust | |||
| | #21 | |||
will go do some window shopping. @argo - totally agree, with the post above this post ![]() here you go eibach pro system 399 euros http://fiat-sportiva.de/product_info...stem-30mm.html
__________________ Previous Car : 2002 Mk2 Punto Active Sport in Broom Yellow Everday Car : 1999 Mk1 Punto Sporting in Silver Weekend Toy : Stilo Schumacher GP Last edited by red-devil; 16-07-2008 at 21:15. | |||
| | #22 | |||
![]() It's SO hard to find dampers that fit the 2.4. Koni seem to be about the only reputable make
| | #23 | ||
| | #24 | ||
| | #25 | ||
| one with the dark side | Re: New 18's - need to firm up the ride - Help!! | ||
| | #26 | ||
__________________ www.carlin.co.uk Fiat Stilo JTD 115bhp 3DR Green/Blueish! Skyroof | |||
| | #27 | ||
| | #28 | ||
| 5 pots rule!! | Re: New 18's - need to firm up the ride - Help!! here mine, eibach sportlines 50mm front 45mm rear
__________________ Previous Car : 2002 Mk2 Punto Active Sport in Broom Yellow Everday Car : 1999 Mk1 Punto Sporting in Silver Weekend Toy : Stilo Schumacher GP Last edited by red-devil; 16-07-2008 at 22:13. | ||
| | #29 | ||
| | #30 | ||
| | Sc00bie | Grande Punto | 51 | 02-04-2008 14:57 |
| Panda Removals firm | spankysmagicpiano | Panda (Classic) | 7 | 31-08-2007 19:49 |
| | duffman | Stilo | 0 | 10-02-2007 01:19 |
| | scottie2065 | Stilo | 19 | 23-03-2006 12:10 |
| Low and firm | Lex | Bodyshop | 2 | 01-02-2004 21:01 |
