The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 15-07-2008   #1
Trader Rating: (0)
Red led stop blinking
Hi guys
When I lock the car with the button on my key, indicator (red led) flash just once, and after that indicator doesn't blinking, which was the case until yesterday. When I unlock the car with the key (not button) and open the door, alarm start screaming, which is mean that alarm system is OK.
What's the problem?
Thanks in advance
Boby is offline
Old 15-07-2008   #2
Technician
a1ant's Avatar
Trader Rating: (0)
a1ant has donated! United Kingdom
Re: Red led stop blinking
Hi mate,
If you mean the little red light on the fob keeps flashing after you have pressed it, the battery is low and needs replacing (in the fob that is!)
Alan
Seicento Sporting 1.1, Punto 1.9 JTD, Punto 1.3 Multijet, Bravo T-Jet 150 Sport, Impreza STi
a1ant is offline
Old 15-07-2008   #3
Low Rider..............
coyle's Avatar
Trader Rating: (0)
coyle has donated! United Kingdom
or does he mean the red led on the inside on the door card?
coyle is offline
Old 15-07-2008   #4
Technician
a1ant's Avatar
Trader Rating: (0)
quite possibly.... needs clarification
a1ant is offline
Old 15-07-2008   #5
coyle's Avatar
Trader Rating: (0)
here here
coyle is offline
Old 15-07-2008   #6
Trader Rating: (0)
Guys
I mean on red led on the driver's side door, not on key
Boby is offline
Old 15-07-2008   #7
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
So you're saying the red led doesn't flash or does flash after locking the car? On Stilos without alarms it DOES flash.
What alarm have you got fitted?
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 15-07-2008   #8
Big Black Stilo's Avatar
Trader Rating: (0)
mine flashes, however car can throw a wobler and start it flashing after it locked the doors itself on the speed lock thing. Usually this stops flashing on next lock.
I NEED HELP!!!
Fabbrica Italiana Automobili Torino
Big Black Stilo is offline
Old 16-07-2008   #9
Trader Rating: (0)
Arg, I don't know. I bought Stilo last year in Italy (1.9JTD, december 2003, model for 2004). Probably it has factory alarm. Is it possible to see which type of alarm is fitted on my car?
Red led flash just once, when I press the lock button, and after that there is no continous blinking, but alarm still working, because when i open the door with key (not unlock button), alarm start screaming. Two days ago, red led stopped continuos flash after locking. Why?
Boby is offline
Old 16-07-2008   #10
Argonought's Avatar
Trader Rating: (0)
You've got me on that one but if the alarm works anyway is it worth bothering about
Type "factory alarm" into Search and you should find lots of info on the subject.
You may notice I made a big effort to retrofit the factory alarm and failed so consider yourself lucky
Old 16-07-2008   #11
Trader Rating: (0)
I had a similer problem with mine a couple of years ago and got the garage to look at it whilst it was getting serviced. It turned out to be a loose connection, which they fixed. That lasted for about a week when I had to take it back because it had stopped flashing again. I think they fixed it properly that time 'cos it ain't caused me any probs since.
Stilo
Kirbs is offline
Old 17-07-2008   #12
Trader Rating: (0)
Arg, what if some thief consider that my car haven't alarm or maybe is broken-down, and try to steal them? They probably will make a some damage (brake the window, pick a lock...), and you agree with me that it will be more expensive then fix the problem with red indicator.
Kirbs,
Where I can find that connector? Is it in the door, or...?
Boby is offline
Old 17-07-2008   #13
Trader Rating: (0)
Looks like its door card removal time for you dear boy, or at least that's where the problem was with mine. Whilst you're at it why not upgrade your front door speakers and do a little soundproofing as well, you know it'll make sense in the long run!!
Stilo
Kirbs is offline
Old 17-07-2008   #14
muppet42's Avatar
Trader Rating: (0)
My LED has proved a little tempramental on occasion. Sometimes when driving around as normal, it'll start flashing with the central locking not activated. It's not happened much recently though and I wouldn't consider it a major problem.
I just consider it another of the characterful features of RGZ
2003 3dr 1.2 16v Stilo Active in Grigio Steel - De-badged rear and wings, Kamei look mesh de-badged grille, Red Painted Callipers, Fiat Alloy Pedals, Richbrook Aerial/spinner dust caps/tax disc holder/Poppy Coral Air Freshener in Silver, Ripspeed mats and lighter.
muppet42 is offline
Old 18-07-2008   #15
Argonought's Avatar
Trader Rating: (0)
This is fairly common although it's down to the driver rather than any fault on the car.
Basically the lock button is very close to where you put your thumb when starting the car (especially if done in a hurry).
I've lost track of how many times I've done it
vB code is On
blinking gearbox warning led mckeithen Marea > Technical 6 06-05-2008 06:20
Problem.....RED Engine LED always on..... :( tubi Punto > Technical 7 28-02-2006 12:48
Red means stop right??? AppleSei Leisure Lounge 14 13-05-2005 16:31
Red Light Means stop!! steve1219 Leisure Lounge 8 06-03-2005 21:36
What is this red LED? viol8r Bravo / Brava 11 06-01-2005 23:26
