| Hi everybody ![]() I want to know how often you change your oil, filter and what oil do you use? I´m changing oil and filter, every 10,000kms and using Motul 5w40 X-Cess 8100 Synthetic Oil on 2003 1.8 16V. I´m doing it right with the type of oil and the time of change?
__________________ STILO 1.8 5 DOOR DYNAMIC 2003 | |||
| | #2 | |||
| It's about GO! not SHOW! | Re: How often do you change oil and what oil do you use?
I'd have thought 20Km (12k miles) or 12 mths (whichever comes first) would be OK
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic Last edited by Argonought; 14-07-2008 at 18:27. | |||
| | #3 | |||
Here in Guatemala the Fiat dealer told me than I need to change the oil every 5K Kms (3125 miles) lol, I think they only want more money
__________________ STILO 1.8 5 DOOR DYNAMIC 2003 | ||||
| | #4 | ||
| It's about GO! not SHOW! | Re: How often do you change oil and what oil do you use? Perhaps he's used to cheap mineral oil which should be changed more often ![]() Far better to use the very best oil you can buy but only change it at the proper service interval
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #5 | ||
Thanks: 6 Trader Rating: (0) Drives: | Re: How often do you change oil and what oil do you use? At the moment, I only get it changed by the dealership every 12 months as I struggle to do 6000 miles a year. I obvioulsly check the levels every now and again, but the 1.2 uses bugger all oil anyway
__________________ 2003 3dr 1.2 16v Stilo Active in Grigio Steel - Done - De-badged rear and wings, Kamei look mesh de-badged grille, Red Painted Callipers, Fiat Alloy Pedals, Richbrook Aerial/spinner dust caps/tax disc holder/Poppy Coral Air Freshener in Silver, Ripspeed mats and lighter. To Do - Eibach Pro dampers+Sportline springs, OMP strutbrace, GSR induction, exhaust, colour coding, Schumi front bumper, 17/18" alloys, leather interior Last edited by muppet42; 14-07-2008 at 22:24. | ||
| | #6 | ||
| Re: How often do you change oil and what oil do you use? You'll find almost as many opinions on here about oil as there are members! Go for a good fully synthetic and change it and the filter every 6 to 10K and you won't go far wrong.
__________________ Phil Thomas Yellow Peril Then:Yellow Stilo 1.6 16V 3-door - not quite standard ![]() Now: Red Stilo Abarth Schumacher GP Prodrive Last edited by Yellow Peril; 15-07-2008 at 09:51. | |||
| | #7 | ||
| Re: How often do you change oil and what oil do you use? i'm changing oil every 6000 miles on my abarth i've heard the opinion that fiat recommended service intervals of 10 to 12k for the abarth are not realistic - by this time even the best oil will be well broken up thats the reason there are so many 2.4 engines with failed bottom ends
| | #8 | ||
| The modfather | My Panda goes in for its second service some time this week and its only done about 3k since the first one ..never the less short trips and much stop start town driving necessitates the annual service..after this one I will be doing all the servicing myself using Selena oil from fiat ..and I will be doing them at 6k and not 12k as given in the service documents..gearbox oil change will come at 30k again using selena oils..just as I did with the stilo..
| | #9 | |||
If you want to change such an oil more often than the service interval specifies then that's your choice and obviously wont do any harm. However, if you mean you intend to use a cheaper oil and then change it twice as often as the service internal specifies then that to me is madness ![]() Far better to spend the extra money on a good oil to start with and only change as recommended
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #10 | |||||
I'm using Mobil1 Super S semi synthetic whitch isn't cheap at all. The other thing i've got to say is that my bottom end failed when i had Castrol Edge fully synthetic in and was servicing it every 10k. As far as i remember Stu also used good oil - Castrol Magnatec and his engine failed - the man can speak for himself and say otherwise but my guess is that he serviced it every 10-12k aswell. I would say that with changing oil should be like with changing cambelt - every one(well most of people) change it well before recommended interval becouse no one knows when it will fail.
| | #11 | ||
| The Phoenix has landed! | Re: How often do you change oil and what oil do you use? Think the last time my oil was changed was at its service, regularly check the oil levels though. The Stilo doesn't loose much if any oil
__________________ Go Phoenix Go! http://theangrybudgie.blogspot.com/Light Blue 3DR 1.6 Stilo Active - Francesca ![]() - Now with Giugiaro designed Vredestein Ultrac's! - Now with new Xenon's - 17" Stone Grey CLAWS | ||
| | #12 | |||
![]() Did anyone investigate the cause? Bottom end failure would normally be associated with poor maintenance and neglect (running out of oil being the most common) and you certainly don't normally associate it with using a very high quality oil
| | #13 | |||||
I'm not saying that it was v. high quality oil that caused it, i'm just saying that EVERY oil has got it's limited life - it will break up. It just depends on many conditions when. You can't say that it will definately last for 12k miles, but it will more certainly last for 6k miles. Thats my point.
| | #14 | |||
![]() It's only conjecture I know, but there must be many reasons why the bearing shell failed. A tiny fragment of metal or other body could have lodged into the oil feed to the bearing and failure would still then occur no matter how recently the oil had been changed. In fact, you'd do better to point your finger at the oil filter rather than the oil if something like that had happened. Then you have considerations of metal fatigue etc. You could even turn turn this whole discussion on it's head and argue that your engine was destined to fail and might well have failed a lot sooner had you not maintained regular servicing with a top oil brand etc ![]() I'll certainly agree on one point though - changing the oil more frequently than recommended is never going to do any harm
| | #15 | ||
| I generally have the oil changed every 6k miles on my JTD, semi-synthetic goes in and the last oil that went in the car was Selenia Turbo Diesel which my local non-franchise garage sourced at 'the right price'. No particular reason I have it changed at 6k-ish miles other than a strong desire to see the engine last...... so I take care of its servicing as though it were something more 'exotic' ![]() As a sceptic of most modern servicing schedules (particularly timing belt replacement intervals) I suppose I spend an above average amount on keeping things 'sweet' but although nothing is certain it gives me some assurance things should be ok.......
__________________ ![]() '03 JTD Dynamic Grigio Steel with skyroof, Eibach -30mm prokit, Abarth shadow chrome 16" alloys with Vredestein Sportrac 3 tyres, OMP strutbrace. | |||
| Tags |
| oil |
