| | #16 | ||
| Re: How often do you change oil and what oil do you use? I think it is optimal change oil with oil filter every 10 000 km or every year.It is good for your engine and it isnīt cost very much.But it depends on where you drive.If in the city the timer between oil changes could be shorter or if you you drive in the higways or long distances you could change oil after 20 000 km.
__________________ My car: Fiat 126p 650E made by FSM in former socialistic Poland Fatherīs car Fiat Stilo 1,6 16v MY2005 /F/I/A/T/ | |||
| | #17 | ||||||||
| Re: How often do you change oil and what oil do you use? [quote] I hear what you're saying but I still don't follow how this relates to your engine failure? If there was no sign of poor lubrication in the engine then why do you seem to blame yourself for not changing the oil more frequently than the recommended interval. [/qoute] Well, becouse it might have contributed to the damage.
You will prabobly say that i could have had the engine flushed on every service, BUT i think that it's much better to change the oil/filter more frequently and prevent the excess sludge build up rather than going for engine flush every 12k miles after it's been running for the last say 4kmiles with the risk of channels blocked.
So people, always use the best oil you can afford basically and change it as often as you think is reasonable! And Argo, ok lets end this discussion, becouse it seems to me that the only thing you're arguing is my insisting on more frequent services. I totally agree with BeaveR above.
| | #18 | ||
| Re: How often do you change oil and what oil do you use? Palio 1,6-16V, 2000 model: oil change, Castrol RS 0W40 full synthetic, every 7500 KM's together with Fram oilfilter. (that's about 3-4X a year). Fiorino 1,7 Diesel Pick-Up, 1991 model: oil change, Castrol GTD 10W40 semi synthetic, at every 7500 KM's, with Fram oilfilter, also about 3-4X a year.
| | #19 | |||
| It's about GO! not SHOW! |
Don't mind me - I just get a little touchy on discussions of expensive engine oils - and if you check what I'm using then you'll know what I mean
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic Last edited by Argonought; 26-07-2008 at 11:22. | |||
| | #20 | ||
| Fiats since 1973 | Re: How often do you change oil and what oil do you use? I s there a particular reason why you use 0w-30 or is that what was recommended for your car only the grade of oil recommended for my 150bhp is 5w-40 just looking at my handbook would you believe timing belt change 150000km (93000mile) or 5year and first oil change 30000km and then 60000km and so on
__________________ 2007 Stilo Sporting M/Jet 150bhp 2001 Marea Weekend JTD 110bhp now 171bhp He who works and does his best gets his cards just like the rest | ||
| | #21 | ||
| Re: How often do you change oil and what oil do you use? Usually semi syn. no more viscous than 5W - 30, especially regarding Fiat hyd. tappets. Changed at no more than 6k miles, not because the oil has deteriorated , but the standard of filtration is quite poor, so the oil is carrying lots of damaging particles. So if someone could recommend a decent filter I would be happy to let it go to say 10k.
| | #22 | |||
| It's about GO! not SHOW! | Re: How often do you change oil and what oil do you use?
I was really impressed as startup clatter basically vanished and oil consumption is close to zero with no oil leaks. The engine revs like you wouldn't believe The only thing I was a bit disappointed in was I didn't notice an improvement in mpg (although that could be due to other factors)I'm on my 3rd year with it now
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #23 | ||
| Re: How often do you change oil and what oil do you use? Every 4000 miles or 6 Months which ever comes first. Oil used is Selenia WR.
__________________ 2003/03 Stilo JTD 115 Dynamic & 2005/55 Croma Multijet 16v Eleganza ( Both In Black ) | |||
| | #25 | ||
| Shropshire UK | Re: How often do you change oil and what oil do you use?
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. | ||
| | #27 | |||
| Re: How often do you change oil and what oil do you use? [quote=arti_abarth;1651215]
I ask because I had a 1.8 and had a conrod piss out the side of the block. The warrenty engineer tried to blame it on oil starvation, but I compiled a technical report and they agreed with me; it was down to a faulty manufacturing defect. However, Fiat still maintain that it was down to oil starvation (despite my conrod showing no signs that this is true) What was the decided failure in the end?
__________________ Running in a: Broom Yellow 1.8 Dynamic - 3 Door Mintex Brake pads all round; GMax springs, Sony Head Unit, Eagle F1 GSD3 tyres Saving for: Side skirts/Upgraded shocks/Twin exhaust Current problems: Slight Exhaust leak | ||||
| Tags |
| oil |
