Dear all,
I have converted my Stilo Abarth 2002 to LPG. The system used is Tartarini.
At first everything worked fine, but after about a week, a started noticing problems when starting the engine in the morning (cold engine). It goes to 1200 rpm, as it normally should, but stays there only for a few seconds and then drops to 600-800 rpm. The whole car shakes, and it doesn't respond to the throttle. I can only slightly touch the throttle, and pump it on/off to increase the revs to 3000 in order to warm up the engine quicker. If I press the throttle harder, the engine starts exploding from intake. When all of this happened for the first time, I drove the car only on petrol for the 3 days, and then all went to normal, but when I started using LPG same thing happens again. I went to the LPG specialist, and they tried to set some LPG parameters, but none of this helps. They are now sending me to check the pump pressure and the petrol injectors, but I don't think this is the problem, as the car work perfectly before the LPG. If I put it on petrol now, I can hardly get it do accelerate until it reaches 3000rpm... As I have read somewhere, the both ECUs (LPG and the ENGINE) work together, and the engine ECU is setting himself up according to the readings from the LAMBDA sensor. Since LPG is different fuel, and the engine ECU is in liberty to make big adjustments, maybe this is what is going on? Can I somehow lock the engine ECU to preset parameters? Is there a way to reset the engine ECU to his "preset" parameters? Is there any other solution to this problem?
Thanks, Natko.
Thanks, Natko.
