The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 11-06-2008   #1
Trader Rating: (0)
Like Emulating The Sensor Ocs Of Passenger Useful This????????
Emulator Ocs
stec is offline
Old 12-06-2008   #2
Trader Rating: (0)
Re: Like Emulating The Sensor Ocs Of Passenger Useful This????????
Mine is faulty so I will definitely try this. Are you sure it works?
WANTED: Faulty Connect Nav+ for parts, to fix mine.
john55 is offline
Old 12-06-2008   #3
Trader Rating: (0)
Friend I Cannot Assure That It Works, Is Necessary To Prove It And To Erase The Error With The Examiner, I Need That Commented The Post To See If Between All We Can Find The Solution
stec is offline
Old 12-06-2008   #4
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
no need for examiner to clear error.
T14086 is offline
Old 13-06-2008   #5
Trader Rating: (0)
The softwares like Autodata o workshop say that I need the Examiner to erase abs error or advertising airbag error.
I send data of airbag operation.Lateral, Frontal, sensor passenger and clockspring. All data that I send you are written in spanish.
I wait your answer
stec is offline
Old 13-06-2008   #6
Trader Rating: (0)
I wait your answer
No you don't. Both ABS and airbag faults will clear when the fault is fixed. No resetting is needed for any Stilo faults.
john55 is offline
Old 16-06-2008   #7
Trader Rating: (0)
Of All Ways I Believe That We Are Turning Aside Ourselves Of The Subject, Which Is To Emulate The Sensor The Published Circuit
stec is offline
Old 27-08-2008   #8
Trader Rating: (0)
hi, nobody has managed to resolve? , A novelty in the forum bmwfaq achieved but what the sensor has only 2 wires
http://www.bmwfaq.com/f9/aviso-impor...lucion-311158/
stec is offline
Old 28-08-2008   #9
Trader Rating: (0)
I have looked into this and it is not right.
Maybe the old Bravo/ Punto used this system. What is describes is an industry standard occupant DETECTOR system, not a CLASSIFICATION system as used in the Stilo. A detector tells the Airbag system if someone is sitting in the seat. The classification system tells the airbag ECU if it is an adult, a child (under 30KG weight), or the seat is empty.
The BMW sensor is an occupant Detector only.
Stilos use a PWM signal to the airbag ECU. I hope to do further work on this in the future as mine is broken and I am definitely not paying fiat for a new sensor.
john55 is offline
Old 28-08-2008   #10
Trader Rating: (0)
jhon please see page 18 of the first pdf file that is located above, (airbag system stilo.zip fiat), let me know your opinion, thanks
stec is offline
Old 29-08-2008   #11
Trader Rating: (0)
I did. That is not what is in the Stilo. The 100 ohm / 400 ohm switch describes a standard switch used by all european manufacturers. An occupant detector works in this way and so does the passangers airbag on/ off switch in the dash.
The OCS fitted to a Stilo passengers seat is different.
john55 is offline
(T) Faulty OCS sensor XYFAS Stilo 7 4 Weeks Ago 12:11
(G) Want to buy OCS IgorJTD Stilo 13 24-07-2008 18:41
(T) Solving the OCS Airbag Sensor Problem Once and for All larzmaster Stilo 13 26-09-2007 16:41
(T) How to replace the OCS sensor Deckchair5 Stilo 1 09-05-2006 14:20
