| | #16 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 | Re: Emulating the Passenger OCS sensor Thank you very much. But i have more two questions. 1. I'm very sorry but I didn't understand (1/2watt) do you mean 0.5watt OR 1or2watt. 2. There is a slight difference between the colors of wires in the sheme and these in my car.
| | #17 | ||
| | Re: Emulating the Passenger OCS sensor 1/2 ( half as in a fraction) = 0.5 Cant really help you any further with the wiring colour scheme of your car. Dan
__________________ If it aint broke, break it and fix it anyway ![]() ![]() '03 Stilo Abarth, 35mm drop, grooved discs and Greenstuff pads, Cupra front splitter, BMC CDA, 17" Claws, Fiat blinds and guess what? No warnings or flashing lights ![]() | ||
| | #18 | |||
Posts: 1,017 Thanks: 71 Trader Rating: 0 | Re: Emulating the Passenger OCS sensor
The Stilo has a occupant classification sensor. i.e. it tells the weight of the person in the seat and where they are sitting. The resistor works for replacing an occupant detector system. i.e. a simple switch that is triggered when someone sits in the seat.
__________________ WANTED: Stilo Front Ash Tray and Faulty Connect Nav+ for parts, to fix mine. | |||
| | #19 | |||
Some things really are just best left to the experts. Dan
__________________ If it aint broke, break it and fix it anyway ![]() ![]() '03 Stilo Abarth, 35mm drop, grooved discs and Greenstuff pads, Cupra front splitter, BMC CDA, 17" Claws, Fiat blinds and guess what? No warnings or flashing lights ![]() | |||
| | #20 | ||
| | Re: Emulating the Passenger OCS sensor Surely trying to 'fool' the airbag system would be a bad idea. I know that if it was tricked into thinking a person was in it, then it would still only go off if the seatbelt was used. But what would trying to emulate tell it? That there was an adult or a child? You wouldnt want it to think the wrong kind of passenger was in the car and the wrong deployment of the airbag to happen... Get a new sensor peoples
| | #21 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 | Re: Emulating the Passenger OCS sensor You are right! But in Bulgaria from Fiat told me that it's around 200euro. ![]() How do you think: will the airbag open when the OCS sensor doesn't work ?
| | #22 | ||
| | Re: Emulating the Passenger OCS sensor I honestly dont know, on most cars though if the airbag ecu detects a fault, then it will just disable the system. So no airbags.
| | #23 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 | Re: Emulating the Passenger OCS sensor And the driver's airbag will not open ?!?
| | #24 | ||
| | Re: Emulating the Passenger OCS sensor I dont know, depends if its able to just disable certain things or if it just disables the airbag system.
| | #25 | |||
Posts: 1,770 Thanks: 45 Trader Rating: 1 Drives: | Re: Emulating the Passenger OCS sensor
M.
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. | |||
| | #26 | |||
Posts: 23,512 Thanks: 713 Trader Rating: 0 | Re: Emulating the Passenger OCS sensor
Guys, as a responsible forum we have to take the manufactures stance on this; ***THIS POST GOES AGAINST FIAT'S RECOMMENDED METHOD OF REPAIR AND THEREFORE IS NOT REPRESENTIVE OF THE FORUM*** Wether you agree with this or not is entirely up to yourself, its your choice,your car but I hope if you sell the car on that you pass on the information of what you have done to the SRS system to the purchaser. (If you know someone in the trade get them to get the OCS for you,£83)
__________________ Last edited by T14086; 10-01-2009 at 16:34. | |||
| | #27 | ||
| | #28 | ||
__________________ | ||
| | #29 | ||
Posts: 15 Thanks: 0 Trader Rating: 0 | Re: Emulating the Passenger OCS sensor
| | x3me | Stilo | 6 | 09-01-2009 18:43 |
| | XYFAS | Stilo | 7 | 02-11-2008 12:11 |
| | Deckchair5 | Stilo | 1 | 09-05-2006 14:20 |
