FIAT Auto Specialist Team
Thread Tools
Old 07-06-2008   #1
Driver Extraordinaire
minimad99 has donated!
how to change lower suspension arm
I've done this as a seperate thread for ease of searching in the future.
Is changing a lower suspension arm a DIY job or is any special kit required?
Could someone write a brief step by step for me.
thanks
Thanks Hound thanked for this post
minimad99 is offline Reply With Quote Quote
Old 07-06-2008   #2
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Re: how to change lower suspension arm
Hello mate,
You can do it yourself, fairly easy job....... (now i'm doing this from memory as i sold my stilo a few months ago so cant go check exact sizes, but have done a fair few)
1, Jack the car up, (support on axel stands)
2, Remove Wheel
3, Undo the 13mm bolt that secures the ball joint to the hub
4, Use ball joint separator or appropriate tool to remove ball joint.
5, Undo the bolts holding the anti-roll bar to the lower arm
6, Undo the 13mm bolts that secure the front mount of the control arm
7, Undo the 19mm bolt that secures the rear of the control arm
8, Remove control arm
The do the reverse to put it all back...lol
Hope that helps,
Alan
Thanks Hound, minimad99 thanked for this post
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 07-06-2008   #3
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
And here's somes piccies to help you on your way. This is a French Stilo so things may look a little backward - spot the exciting and definitely not recommended method of using jacks here
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 08-06-2008   #4
cheers Decks,
You're a legend.
Old 09-06-2008   #5
NobodyBlamesTheHappyGuy!
Morty Mort's Avatar
Trader Rating: 2
Morty Mort has donated!
Norway
Quote Originally Posted by minimad99 View Post
cheers Decks,
You're a legend.
And still alive.
jet blue. eibach pro system. omp bar. gsr in. supersprint out. hella eyes. phoenix gold watts.
member of the 5-door massive attack.
Morty Mort is offline Reply With Quote Quote
Old 09-06-2008   #6
Deckchair5's Avatar
Hi Morty! I'm still kicking
Drove a motorbike for the first time in 30 years tonight. A Bonny! (Triumph Bonneville) Bike was nearly as old as me. Still buzzing
Forgot how bad the brakes were
99 Bravo 1.2SX
Old 09-06-2008   #7
Morty Mort's Avatar
Trader Rating: 2
Norway
Quote Originally Posted by Deckchair5 View Post
Hehe. I took the motorbike theoretical exam when I was serving time in the Norwegian army. Then after testing the bikes, I put it on the shelf. Something told me this was going to kill me. So I never took the license...
Thread Tools
(T) Changing the Front lower suspension arm ChrisMClark Stilo 17 05-09-2007 23:08
(T) Lower Front Suspension Arm G Spag Stilo 6 14-04-2007 04:12
(T) O/S Lower Suspension Arm leelee01 Stilo 6 04-02-2007 03:31
(T) Lower suspension arm (Wishbone) DAlex Marea 8 03-12-2006 00:56
(T) Changing front suspension arm bushes(change to guide format) peaster2k Cinquecento / Seicento 2 21-02-2005 19:57
