The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 01-06-2008   #1
JoskeJTD's Avatar
Trader Rating: (0)
Windscreen Washer Jets - Mist Type
Hi, i was wondering which Stilo models where fitted with windscreen washer jets that spray a mist rather than a jet of water?
I've checked eper and im not sure which ones are which, they also state some washer jets as being heated. Can anyone explain how that works as i can't see any electrics going to them to heat them.
If anyone has the time to take a photo of there washer jet that sprays mist i would appreciate that so i know which to get or if possible provide with the dimensions of the washer jet as i want to fit them to another car.
Many Thanks in advance.
ePER 4.0 DVD 2008 / Fiat Bravo Haynes Manual / Fiat Bravo & Fiat Coupe Workshop Manuals and Fiat Bravo Owners Manual in Electronic Format. £5 Delivered.
JoskeJTD is offline
Old 01-06-2008   #2
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: Windscreen Washer Jets - Mist Type
I didn't know any did and can't see the point to be honest
If you've ever tried cleaning the windscreen when it's very windy then you'll soon see that a mist is about as useful as a hole in the head
Pre-heating the washer fluid is normally done via a jacket inserted in the heater system. My experience is you're pretty much forced to use distilled water to stop minerals dropping out of solution once the system cools (jets alway blocking )
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 03-06-2008   #3
JoskeJTD's Avatar
Trader Rating: (0)
Since you've not actually seen them working then you really can't comment. In regards to your comment on heating they are infact wired into the cars loom and they are operated via there own thermostat.
Back on topic the mist washer jets work alot better than the standard jets. They spray over most of the window unlike the jets and they dont seem to get blocked up either.
Can anyone tell me if they have it on there Stilo or does nobody have it.
JoskeJTD is offline
Old 03-06-2008   #4
Argonought's Avatar
Trader Rating: (0)
If you know so much about them then I'm surprised you bothered to ask
I assure you I've driven a car with heated washer jets and the operation is exactly as I've described (obviously not a Stilo).
However it's quite possible that electrical heating, which would normally be considered very inefficient, at the point of exit (at the jet/spray) may overcome the blockage problems I've previously mentioned.
Old 03-06-2008   #5
hot hot tamale!
Hellcat's Avatar
Trader Rating: (3)
Hellcat has donated!
Bravo has spray washer jets if that's any help?
Hellcat is offline
Old 03-06-2008   #6
Panda's with Gadget's
Most Easterly Pandas's Avatar
Trader Rating: (0)
Most Easterly Pandas has donated! United Kingdom
I've always thought that the 'Spray' type are better. I don't think they're suppost to mist much, just spray in a shape. Would normally look like a long flat hole on the jet.
Jon.
Most Easterly Panda's - Panda'ing in East Anglia
5 Panda's! 1989 F-reg 750L, 1991/1992 (not sure as on a NI plate) Panda 1000CL,
1993 K-reg Selecta (1108cc) x2! 1988 E-reg Sisley 4x4
Originally Posted by Jai View Post
grip the meat, loosen the throat, relax and slide it in
If my post or someone else's has helped, say thank you using the Thanks Button \/
Most Easterly Pandas is offline
Old 03-06-2008   #7
Argonought's Avatar
Trader Rating: (0)
That would make a lot more sense
Old 03-06-2008   #8
JoskeJTD's Avatar
Trader Rating: (0)
Im still non the wiser. Ok well i've found several cars to use the mist jets rather than the normal jets of water. Guess its a case of going to the scrapyard.
JoskeJTD is offline
Old 04-06-2008   #9
Trader Rating: (0)
Let us know how you get on and what car's you get them off of. Won't be able to fit one to my panda because of the shape of the nozzle, but might fit a set to mum's Yaris.
Do you think the water pump might have to be a certain pressure to force the water out at speed to make the shape?
I don't know how powerful the pump on the Stilo is, but it might be worth concidering!
Jon.
Old 06-06-2008   #10
JoskeJTD's Avatar
Trader Rating: (0)
Jon.
I used a Citroen/Peugeot mist washer jet to fit to my Bravo, i needed to make a custom clip to hold it in place but it worked a treat.
JoskeJTD is offline
The following user says "Thank You!" to JoskeJTD for this useful post:
Most Easterly Pandas (06-06-2008)
Old 06-06-2008   #11
Shropshire UK
Ffoxy's Avatar
Trader Rating: (0)
Ffoxy has donated! United Kingdom
GP's have these as standard, very cleverly FIAT achieved this by making the washer nozzles non-adjustable but point them at the wiper blades rather than the screen...
Hey Presto... Instant Mist!
Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque.
Ffoxy is offline
Old 06-06-2008   #12
Trader Rating: (0)
Lol.
Old 08-06-2008   #13
Trader Rating: (0)
Mk2b puntos have mist jets, but mk2 puntos have jets, so look out for a 2b while at the scrappy
Lee_JTD is offline
Old 11-06-2008   #14
Trader Rating: (0)
What the difference in these mk2's?
Jon.
Old 12-06-2008   #15
performancestilo.co.uk
stilosporting's Avatar
Trader Rating: (5)
stilosporting has donated! United Kingdom
i had the mk2b and it didnt have mist type washers?
www.reddotracing.co.uk
162.6bhp 219.8ft-lb
stilosporting is offline
(T) Washer Jets Kezza Grande Punto 10 07-04-2008 16:35
(G) Washer jets Brooksy Bravo / Brava 4 04-03-2008 14:27
(T) GP Windscreen washer jets Ffoxy Punto 1 24-05-2007 11:06
(T) washer jets supacook2k Bravo / Brava 28 10-02-2007 18:37
Front Windscreen washer Jets petebarchetta Panda (New) 5 22-01-2007 21:41
