| | #16 | ||
| Re: Fitted my Xenons..Heres How personally i wouldnt put aftermarket xenons unless they come from the manufacturer. One reason is that the halogen reflector is not designed to be used with a xenon blub resulting in dissipation of light all over the place blinding the other driver. If you guys see a stilo with xenon or any other car there is a totally different lens covering the front of the lamp.Also there is a chance of interference with the electrics since the electricity is boosted to thousands of volts, in addition to the delay for the xenons to turn on right away. Here is aftermarket xenon which is all over the place ![]() Here is with halogen and see how the light cuts off on the top ![]() Now see with a proper xenon light bulb housing from the manufacturer ![]() http://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps http://ken-gilbert.com/wrx/lights/139655_web.pdf http://ken-gilbert.com/wrx/lights/159492_web.pdf http://ken-gilbert.com/wrx/lights/159496_web.pdf http://ken-gilbert.com/wrx/lights/159497_web.pdf http://ken-gilbert.com/wrx/lights/176157_web.pdf http://ken-gilbert.com/wrx/lights/222580_web.pdf http://ken-gilbert.com/wrx/lights/809-669.pdf http://ken-gilbert.com/wrx/lights/BadBlueBulbs.pdf http://ken-gilbert.com/wrx/lights/causesGlare.pdf http://ken-gilbert.com/wrx/lights/causesGlare.pdf http://ken-gilbert.com/wrx/lights/PAL2001-akashi.pdf http://forums.nasioc.com/forums/show...hreadid=455815
__________________ 1.6 silver dynamic 3d with skywindow, Schumacher Look, Abarth Pedals,Brembo Brakes,Bilstein Eibach Suspension, Eagle F1 Tires, K&N Filter,Sport Steering Wheel,Sport Knob,3M tint.Philips New Vision Lights. Founder & Admin of the Greek Stilo club www.stiloclub.gr Last edited by Stilatos; 05-05-2008 at 16:14. Reason: extra info | |||
| | #17 | ||
| 5vp3r m0d | Re: Fitted my Xenons..Heres How Ok, any chance this can be made into a guide - you will also need to use the Forum attachment facility for the pics, NOT the Gallery NOR a photobucket site. I will also be able to move across any comments from this thread, once done, then lose this thread totally
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #18 | |||
| EgyTuner.com... | Re: Fitted my Xenons..Heres How
i havent at all noticed a difference in the stilo xenon lens, nor on a renault laguna | |||
| | #19 | |||
| It's about GO! not SHOW! |
![]() For starters, you lose the fog light from the lamp assembly and I presume there's a reason for that
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #20 | ||
| has pooped his pants | Re: Fitted my Xenons..Heres How You can almost guarentee that the halogen bulb reflector is not correct for a xenon bulb as the HID arc and a halogen filament are in different positions and are different shapes...
__________________ ![]() 02 Fiat Stilo Abarth (5dr) Navy Blue, Cream Full Leather Interior, 17" Anthracite Alloys with Goodyear Eagle F1 Asymmetrics, Schumi GP Prodrive Suspension (Eibach Springs and Bilstein Dampers), Denso Iridiums, EBC RedStuff Pads. To Do: OMP Strutbrace, BMC CDA, Cat-back Exhaust | ||
| | #21 | ||
| Orate Laar.. | Re: Fitted my Xenons..Heres How I didnt need to drill anything anywhere. there are only two very small thin wire which have to go through the casing. and they actualy fit past it when closing the casing with no problem at all. and as for turning it to a guide. is it worth it. or better to just leave it here? as it is still findable using 'Search' i dont mind either way. as long as people find it helpful.
__________________ ![]() | ||
| | #22 | |||
the kit was £75 delivered. and the road illumination is much better. the colour makes alot of difference. can see much further
__________________ ![]() | |||
| | #23 | |||||
LOL, i must have small hands! Nice one mate thanks for the information...I will look into doing this when my current bulbs blow.
| | #24 | ||
| The following user says "Thank You!" to coyle for this useful post: | ||
jostheboss (09-05-2008) | ||
| | #25 | ||
| Re: Fitted my Xenons..Heres How nice
| | #26 | ||
| Orate Laar.. | Re: Fitted my Xenons..Heres How cheers mate
| | #27 | ||
| | #28 | |||
The collar on the indicator stalk has an A - automatic position to activate the daylight sensor switching of the dipped beam. Not sure if this is Xenon only or a general option with either type of headlights. You cant use main beam on Auto though, have to turn the collar through off & sidelights to the other dipped beam position to get main beam! Other thing I discovered when upgrading mains to Extreme +80's is that they're H7's and NOT H1's per handbook etc! Yes Xenon's are on Dipped beam only, main beam is just a standard bulb and mine had 'yellowed' in their 3.5 - 4 years fitted to the car. 20 months & 33+ K on would comment that the beam pattern is so clear and crisp on dipped beam with the factory Xenons that front fogs are of little consequence or value. Uprating your main beam is essential though as stock H7's mains look pathetic versus factory Xenons. I went Phillips Extreme +80%'s which get the Auto Express Previous 1.6 had standard front lights and I uprated dipped & mains with Halfords Brilliance +50%'s, again highly rated by Auto Express. The difference is +50% (best available Autumn '05 when fitted) on the 1.6 gave a lot more light to illuminate the road ahead but the JTD's Xenon's subtley pick out detail at an amazing range without flooding the road with light giving much more clarity. The Extreme 80's add a lot of light in between & ahead of the Xenons ![]() Nice guide/thread thought coyle... will no doubt refer to it when I get round to fitting fresh sidelight bulds which have been in my garage forever! 2 on nearside discoloured/dim for some reason
__________________ Black 115 JTD, 15' Steelies with Doblo trims & debadged +147 Cruise Control NOW with added Millers Diesel Power Sport 4 Last edited by wotnowarninglight; 06-05-2008 at 13:15. | ||||
| | #29 | ||
| Orate Laar.. | Re: Fitted my Xenons..Heres How I havent upgraded my full beam or fogs at this time. but with the xenons on, the fogs make basically no dofference, and full beam is only higher, so again not a massive difference. one thing i have noticed is I can have the xenons and fogs on at the same time. or xenons and full beams. but if i try and put all 3 on then the xenons(dipped beam) turns off. is this the case with the standard dipped beam as i never noticed it before? or is this something which has just started happening with the new HID's?
| | #30 | ||
| It's about GO! not SHOW! | Re: Fitted my Xenons..Heres How Summing up the posts from this thread it seems Coyle has produced a nice guide on how to change headlamp bulbs but unfortunately has gone on to show how to make your Stilo completely illegal Some of the HID kits available, typically off eBay, look decidedly dodgy. Reading some of the (bad) feedback seems to indicate that companies in China produce packaging containing well known branded logos which are nothing but copies so it's easy to see how people get conned.
| | XIIX | 500 | 96 | 1 Week Ago 19:24 |
| | Grande punto88 | Grande Punto | 49 | 19-12-2007 16:38 |
| Who has fitted Coilovers? I still havent got mine fitted right | dave | Lets Talk FIAT | 29 | 25-01-2006 14:06 |
| | mmarkcooper | Stilo | 17 | 10-11-2005 07:12 |
| | RealRiledOne | Stilo | 4 | 06-07-2004 15:36 |
