Posts: 142 Thanks: 10 Trader Rating: 0 | OBD II Cable Anyone seen any cables anywhere to connect the stilo to a laptop preferably cheap?
Posts: 4,160 Thanks: 347 Trader Rating: 0 | Re: OBD II Cable Try http://www.talktomycar.co.uk/ Check what kind of ports you have on your laptop first though ie serial female/male / usb? ![]() Do a search on here first though if you plan to use it on a JTD as earlier ones aren't EOBD2 compliant
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 01-05-2008 at 09:04. | ||
| | #3 | ||
Posts: 1,015 Thanks: 71 Trader Rating: 0 | Re: OBD II Cable ebay is usually the cheapest. U380 or U480 scanners seem to work well on stilo's
__________________ WANTED: Stilo Front Ash Tray and Faulty Connect Nav+ for parts, to fix mine. | ||
| | #4 | |||
Posts: 6,426 Blog Entries: 1 Thanks: 244 Trader Rating: 0 Drives: |
![]() Anyway - have you used these code readers with your 2002 Stilo because I might get one as nothing else seems to work? Is the U480 (CAN bus) model likely to be more compatible than the U380?
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #5 | ||
Posts: 142 Thanks: 10 Trader Rating: 0 | Re: OBD II Cable Read your other thread on trying to link to a computer have you given up on this then? I suppose all you really need to do is read any error codes and reset them, just using it with a laptop seems so much cooler
| | #6 | |||
__________________ WANTED: Stilo Front Ash Tray and Faulty Connect Nav+ for parts, to fix mine. | |||
| | #7 | |||
Posts: 6,426 Blog Entries: 1 Thanks: 244 Trader Rating: 0 Drives: | Re: OBD II Cable
I still think there's something odd here as whilst I can't talk to the ECU (strictly speaking I can but it refuses to initialize so you don't get very far ) the car has recently been mapped successfully via the OBDII interface. The guy even said I was lucky I had a fast ECU which meant the remap took only minutes instead of nearly an hour. Clearly some interfaces, apart from just Examiner, can talk to it OK
| | #8 | |||
| | #9 | |||
I might try one (I'll make sure I'm offered a 7 day return )
| | #10 | ||
| | Re: OBD II Cable Thanks to Steve148 so far it wont give me what i want from my 2005 stilo jtd but im not giving up just yet.
| | #11 | |||
| | #12 | |||
| | #13 | ||
| | Re: OBD II Cable not the same laptop no but same software and interface (elm323). i think his laptop is xp and mine is vista but that is the only difference. i have checked though and the driver states it is compatable with vista.
| | #14 | |||||
| | Re: OBD II Cable ![]()
| | #15 | ||
Posts: 1,015 Thanks: 71 Trader Rating: 0 | Re: OBD II Cable Make sure you run the software in XP compatible mode and as administrator. Right click on the launch icon and set these properties. Otherwise software like this tends not to work on Vista.
| | sjladopoulos | Barchetta | 15 | 4 Weeks Ago 19:30 |
| | ronnieronson | Cinquecento / Seicento | 4 | 21-02-2008 22:51 |
| | bajeknight | Bravo / Brava | 1 | 20-09-2006 11:08 |
| | Tim T | Stilo | 5 | 19-07-2006 19:00 |
| | arc | Cinquecento / Seicento | 19 | 18-05-2005 23:42 |
