Ben B
Member
My girlfriend's Stilo had "engine fault" appear on screen about 100 yards from home. I worried at first that it might have been the coolant problem (that keeps getting low-it's either a headgasket or a simple leak) maybe it boiled dry, overheated and destroyed itself, but when I went to check it I found the water no lower than minimum and the temp fine.
So the car is due to go back to the garage under the 3 month warantee tomorrow for the coolant problem, which is a bit of luck, but how serious is the engine fault likely to be, and will it be safe to make the 40 minute drive to the garage tomorrow while it's still saying that on screen?
