The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 24-03-2008   #1
Fiats since 1973
johnson550's Avatar
Trader Rating: (0)
johnson550 has donated! United Kingdom
Radio Removal Keys
Would anyone kindly show me a pic of radio removal keys I made two like the one in the pic it fits champion but radio wont come out
2007 Stilo Sporting M/Jet 150bhp
2001 Marea Weekend JTD 110bhp now 171bhp
He who works and does his best gets his cards just like the rest
johnson550 is offline
Old 24-03-2008   #2
Veracocha
bozzy's Avatar
Trader Rating: (3)
bozzy has donated! United Kingdom
Re: Radio Removal Keys
Not sure they are long enough. I used two coathangers (thick & long). Also open the upper glovebox which will allow you to get a flat bar behind the fascia.
bozzy is offline
Old 24-03-2008   #3
Fiats since 1973
johnson550's Avatar
Trader Rating: (0)
they dont go right in before they hit somit
Old 24-03-2008   #4
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
I always used coathangers, worked for me.
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 24-03-2008   #5
Veracocha
bozzy's Avatar
Trader Rating: (3)
Can't remember mine coming to a stop, really had to force them right in.
bozzy is offline
Old 24-03-2008   #6
popping out
dan-the-man's Avatar
Trader Rating: (0)
dan-the-man has donated! United Kingdom
They need to look like this. pointed bit has like a lump on the end.
Check out my Microsoft Paint skills
MR2 owner!!!!!!!
dan-the-man is offline
Old 24-03-2008   #7
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
i used wooden kebab sticks today
Binki
dave is offline
Old 24-03-2008   #8
Fiats since 1973
johnson550's Avatar
Trader Rating: (0)
the wire I used must have been a fraction of a millimetre too thick cause I used a wire coathanger and it worked fine
Old 30-03-2008   #9
Trader Rating: (0)
you need a tool number 1860897000 this would remove the radio from the fiat marea but i dont know where you can get them anybody got any idea's
paul.bryan is offline
Old 30-03-2008   #10
^ me
nightsmith's Avatar
Trader Rating: (0)
nightsmith has donated! United Kingdom
i actually used cocktail umbrellas to get mine out
nightsmith is offline
Old 30-03-2008   #11
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
4 short pieces of brazing rod/wire or 4 standard pins (opening post) obviously bent flat.
T14086 is offline
Old 17-09-2008   #12
Trader Rating: (0)
I've got the proper removal pins, but the swines won't go far enough in to engage the removal mecahnism. I even tried belting them with a hammer but they still won't go in properly. ARGH! Might see if my neighbour's got a rubber mallet......
Any tips for getting the things to engage properly? Might try dipping them in washing up liquid......
Alanovich is offline
Old 17-09-2008   #13
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Well be careful because the pins probably have gone in far enough, they only need to go in a couple of inches (50mm) to release the catches. The problem is that unit sticks to the soft plastic dashboard and can take a lot of careful levering and prising to the sides before it will release
A 5p length of ordinary welding rod cut into 4 pieces each 6in long will do the job absolutely fine
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 17-09-2008   #14
Trader Rating: (0)
Ah, thanks! The pins are about 50% submerged into the holes, so I thought they weren't in far enough as the radio simply won't budge. I'll have another go tonight at wiggling them about and will desist from belting them with my hammer!
I have a replacement Visteon CD unit in hand (finally bagged one on ebay), and put the keys down through the holes on that so that I could see how far they were going. The same happened - they go about 50% of the way in, and I don't see the ends poking out anywhere. It looked to me like they weren't going in far enough to engage the grooved-looking retaining clips which look they they would need to be pushed back in order to release a fitted unit from its berth. It really looked like they would be doing absolutely no good in a fitted unit as they just sit in small black plastic tubes which don't reach as far as what looks like the retaining clips.
All very odd.
One other question - when the removal keys are in place, should they catch hold of the unit, and then you pull on them to take the unit out, or do you just insert the keys then grab the body of the unit to remove it?
Old 17-09-2008   #15
Deckchair5's Avatar
Trader Rating: (0)
No, you have to lever on the sides of the unit, do one side at a time with the largest flat blade levers or screwdrivers you can find
Snap! OOps! Sufficient force without being excessive
99 Bravo 1.2SX
The following user says "Thank You!" to Deckchair5 for this useful post:
Alanovich (17-09-2008)
Radio Removal deckstermx3 Scudo 5 28-08-2007 19:20
removal keys punto mk1 JjPhoenix I.C.E 7 04-05-2007 12:11
(T) radio removal Grim_Evil Stilo 17 20-10-2004 12:01
(G) Radio removal arc Punto 0 07-09-2004 18:13
(G) Stilo Radio Removal monster109 Stilo 6 18-08-2003 02:50
