Hi guys, I can only back up what already has been said, which is that a quality brake pad will go a long way if installed correctly (not much can go wrong but I read a few kinks here and there that can happen to cause premature failure or squeaking).
I had our Stilo 1.6's pads changed at last service about a thousand miles ago because they screeched horribly enough that it turned heads sometimes, they were not shot completely but +50% or more.
The composition of a brake pad depending on it's manufacturer and it's quality varies. Some contain more metals than others. Some wear longer but start to "sing" sooner or vice versa. I just had put in quality pads, not the most high classed but very good mid range ones, and presto, screech stopped, brake working perfectly since.
I'm told by my mechanic that certain pads with certain types of disks will emit sounds, usually not pleasant sounds, when breaking even when new
It's down to their compositions.
I cant give a definitive answer to your problem sadly I can only back op what has been said before, good pads with disks in solid condition will go a long way and without annoying sounds
