| Door wont open As the title says, my drivers door wont open, and its a right pain using the passenger door to get in, and no doubt the missus is going to scratch all the dash and connect+ screen with her heels whilst getting in.....................................So!!! How do i get it open? the central locking system is working in the door, and the handle is unlocking the lock from the inside, but the door wont open. It seems as if the deadlock is stuck on. I use the deadlock feature everytime i lock the car, so its not like the deadlock is stiff, or seized. But thats what it seems to be. I dont want to be told that i have to remove the door card, coz thats impossible with the door shut. So i need other solutions. such as is there a way to deactivate the deadlock with the key in the barrel? I look forward to your replies, that tell me that i dont need to remove the door card
| Whaddya mean too old? | Re: Door wont open It's not impossible to remove the door card with the door shut, difficult yes, but it's the only way to gain access to the lock. Otherwise all you can do is play and pray with the remote and door lock key. Deadlocks are a pretty daft feature as a pane of glass won't stop a determined thief gaining access to the inside of your car. All I've ever heard of deadlocks is the owner themselves being locked out of their own car. Deadlocks were discontinued on later models I believe. I have them but have never used them for that reason. I wish you luck
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 16-01-2008 at 09:17. | ||
| | #3 | ||
| The Phoenix has landed! | Re: Door wont open Ive had this exact problem, when my Stilo went in for its suspension recall work the guys at the Fiat garage said it was the central locking motor in the door that had gone kaput. They quoted some silly price to sort it so took it to my independant garage and they sorted it. Pretty sure the parts + labour were well under £100! Take it to a garage and ask them to check the motor, im pretty sure that will be it!
__________________ Go Phoenix Go! http://theangrybudgie.blogspot.com/Light Blue 3DR 1.6 Stilo Active - Francesca ![]() - Now with Giugiaro designed Vredestein Ultrac's! - Now with new Xenon's - 17" Stone Grey CLAWS | ||
| | #4 | ||
| Re: Door wont open But i can hear the motor working, unless the deadlock has its own motor? a few weeks back when the car was frozen i had the same problem, but when the car warmed up, the door would open again. I need all the luck i can get, lol
| | #5 | ||
| It's about GO! not SHOW! | Re: Door wont open I'd leave it while until there's fair change in temperature. You never know it might suddenly clear. (and just hope the other door doesn't jam )I only use mine at high risk locations like when I'm going for a hike and the car's parked on the moors.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #7 | ||
| Whaddya mean too old? | Re: Door wont open The deadlock is a separate motor to the normal lock/release motor. It sounds as if the deadlock is just jammed if the normal door catch is working as that shows the door node is receiving signals Door catch is N50 D/L is the deadlock Door node is M66 Interior door lock switch is H44 Just keep playing with the remote or key in the door and maybe lean on the door near the catch Look like you're breaking in, get arrested, spend a night in the cells, protest your innocence, meet a nice chap called Vincent, wish deadlocks were never invented
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 16-01-2008 at 17:18. | ||
| | #8 | |||||
| Re: Door wont open
Thanks for the info tho' decks. I'll be out first thing in the morning, dressed like a twocer, lol
| | #9 | ||
| Re: Door wont open sorry for silly question but how to use deadlocks?? how do you know if the car is locked or deadlocked??
| | #10 | |||
a double click of the lock button should produce 3 confirmation flashes from indicators to indicate the car is deadlocked. You can normally also hear the bolts slide into place.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #11 | ||
| Whaddya mean too old? | Re: Door wont open Never had a problem with deadlocks because i don't use them. Moral there somewhere
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 16-01-2008 at 20:30. | ||
| | #12 | ||
| Grumpy Forum Moderator | Re: Door wont open your dealer should be able to over ride them & open the door...done this many times.
| | #13 | ||
| Re: Door wont open Any tips on how a dealer might go about over riding the deadlocks? ![]() Software and examiner based over ride, or big hammer style overide?
| | #14 | ||
| | #15 | ||
| Re: Door wont open Ok so i got the door open, i just played with the locks, and both internal and external handles, and then oila! it opened. Its worked perfect ever since. I think the missus buggered it up! and then hid the truth from me. But its working no. Champion!
| | GrumpyOldMan | Cinquecento / Seicento | 17 | 06-11-2007 00:58 |
| | Mike88 | Punto | 1 | 14-08-2007 09:09 |
| | cobwebdesignz | Bravo / Brava | 6 | 13-02-2007 10:01 |
| Die Hard!!! | The Negotiator | Leisure Lounge | 27 | 24-04-2006 22:20 |
| | beau | Uno | 3 | 05-10-2005 09:43 |
