| It's about GO! not SHOW! | The Stilo is just outside Paris at the moment and I'm getting quite a few French drivers flashing me at night. I've fitted some stick on converters but the stupid thing is I've little idea where to put them on the headlamp and they're obviously in the wrong place (tried a few different positions). Has anyone got an image of where they should be placed (I think the position is marked on the OEM Fiat Headlamp protectors but I don't have those ) ?Apart from that the Stilo is driving great!
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| Dislikeskeyboardwarriors | Re: Headlamp Conversion (for mainland Europe) stilojoe is selling a set, might give a bit of guidance from the pic shown http://www.fiatforum.com/classifieds...ct=8758&cat=68 have a look there
__________________ | ||
| The following user says "Thank You!" to Steely for this useful post: | ||
Argonought (31-12-2007) | ||
| | #3 | ||
| Whaddya mean too old? | Re: Headlamp Conversion (for mainland Europe) They're probably just saying "Bonjour Anglais" as the French just love English tourists Flash them back, they'll love you all the more
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #4 | ||
| loves you lots ;) | Re: Headlamp Conversion (for mainland Europe) surely it cant be that bad if you can still drive it okay over here, or have they got more sensitive eyes ![]() they might just love your car ![]() be sure to get a few pictures of it there, near the l'arc the triumph, chante lisae, eiffel tower etc ![]()
__________________ FIAT STILO..... ABARTH IN DISGUISE ![]() SCORPION BADGES, SKYROOF, 17" ANTHRACITE BLADES, ABARTH SIDE SKIRTS AND SPOILER, BLACK OUT WINDOW BLINDS PREVIOUS: 54 CORSA 1.3CDTI SXI - WRITE OFF ![]() 05 MICRA 1.2 16V SE - IN PURPLE - PART EX ![]() | ||
| | #5 | ||
| one with the dark side | Re: Headlamp Conversion (for mainland Europe) Untill you get it sorted set your headlight adjusters to '3' and that will reduce the blinding affect. | ||
| | #6 | |||
| FFFTW! | Re: Headlamp Conversion (for mainland Europe)
... or atleast i think its something along those lines.
__________________ If my post has helped you, please click the Thanks button ![]() | |||
| | #7 | |||||
![]() Never driven abroad then josh the reason they are flashing him is the way His car headlamps are set up for the UK..your passenger side headlamp is aimed high and to the left to pick up the edge of the road and signs and your drivers side is set lower and more of a fan shape to illuminate the road.. obviously when your driving on the "wrong side" of the road you left hand lamp is shining into the eyes of oncoming cars... Do you have your hand book with you Argonought? on my punto there is a diagram in the book as to where to put black tape to mask out the light (surely the stilo is the same?)
| | #8 | ||
| It's about GO! not SHOW! | Re: Headlamp Conversion (for mainland Europe) Thanks guys I`d already tried a similar position to that shown by Steely, so what I did in the end was get someone to stand in the position of an oncoming car and simply move the mask around until he wasn't blinded so much. Seems it needs to be a bit higher than shown on the protectors ![]() There's absolutely no information in the handbook and as I've already said no markings on the hedlamps at all ![]() I'll post an image when I get back in case it helps anyone else
| | #9 | ||
| Re: Headlamp Conversion (for mainland Europe) If the headlamp convertors you're taling about are 'beam benders' then you typically just place them over where you can physically see the headlamp bulb for the main lights. As stated above, most modern cars with clear headlamps don't have any markings on them as was common on cars with 'frosted' glass headlamps.
| | #10 | ||
| Pick a window,your leavin | Re: Headlamp Conversion (for mainland Europe) Has anyone ever priced up how much it'd cost to get a pair of European headlight clusters? I generally spend minimum 6 weeks a year working in Germany, and I'm planning on taking the car next time (when we're out there we're only 1 1/2 hours from Nurburgring ) so I'd like to get the actual clusters in there rather than messing about with beam benders.
| | #11 | |||||
Surely the European ebay sites e.g. ebay.it, ebay.de, ebay.fr are worth a try?
| | #12 | ||
| It's about GO! not SHOW! | Re: Headlamp Conversion (for mainland Europe) Just in case it helps anyone else this is where I ended up placing the beam converters (obviously it's the same position on each side). These are semi-translucent simple prisms but the position should be much the same for blanking masks.
| | #13 | ||
| Panda's with Gadget's | Re: Headlamp Conversion (for mainland Europe)
__________________ Most Easterly Panda's - Panda'ing in East Anglia ![]() 5 Panda's! 1989 F-reg 750L, 1991/1992 (not sure as on a NI plate) Panda 1000CL, 1993 K-reg Selecta (1108cc) x2! 1988 E-reg Sisley 4x4If my post or someone else's has helped, say thank you using the Thanks Button \/ | ||
| | Aresby | Grande Punto | 9 | 29-09-2007 23:21 |
| | kritip | Cinquecento / Seicento | 15 | 04-08-2007 13:29 |
| | bwooly318 | Punto | 19 | 27-07-2007 18:02 |
| | cinqsandminis | Cinquecento / Seicento | 17 | 15-04-2005 21:51 |
