| Cigar Lighter Change Heya everyone. This is my first post in the forum, wonder if anyone can help!? I have a 5dr 1.2 Stilo Active and would like to change the cigar lighter. It doesnt hold my Mp3 player plug well as it just keeps popping out and doesnt charge it up. My SatNav one still doesnt secure properly but at least it can get a charge going. Went to Fiat the other day and they said it would be about £15 to buy a new one which aint that bad, but then they wanted like £60 to fit it, which I thought was steep for a silly lighter lol Does anyone know how I could change it myself? Think the middle section might need to be taken out, but havent a clue where to start with that lol My sister has just bought a new Punto Grande and they have power outlets instead of cigar lighters....would prefer one of them! Thanks
| micks@live.com :o pwnage | Re: Cigar Lighter Change I too would like to know more about this since the one in my car you have to turn the satnav charger thing around slowly untill see green light on it so it will charge :/ so could do with new one.
__________________ Broom Yellow Stilo Dynamic 1.8 : Twin Exhaust | Rear/Back windows tinted | 17" Claws Alloys| More to come. | ||
| | #3 | ||
| Pick a window,your leavin | Re: Cigar Lighter Change I would think it's easy enough to change it, but what I've done is actually take a feed from the battery into the upper glovebox and wired in a 4 way cigar socket splitter. You keep it looking original and give yourself 4 more sockets without cables all over the cockpit.
| | #4 | ||
| It's about GO! not SHOW! | Re: Cigar Lighter Change Be a lot easier to extend it towards the front of the car surely ![]() I've done that to mine - just used a double socket
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #5 | ||
| Pick a window,your leavin | Re: Cigar Lighter Change Was easy enough, but I already had the feed from when I had the amp in the boot. It's only one cable and it's near enough exactly where you need it coming through the bulkhead.
| | #6 | ||
| loves you lots ;) | Re: Cigar Lighter Change Mine works finely only problem is that its set quite far back, so you have trail the sat nav lead all around to the front of the windscreen .i try and charge my satnav up before i set off (home charger), and prefer it to be at the right hand side of the windscreen where its out of the way, and a little bit easier to see
__________________ FIAT STILO..... ABARTH IN DISGUISE ![]() SCORPION BADGES, SKYROOF, 17" ANTHRACITE BLADES, ABARTH SIDE SKIRTS AND SPOILER, BLACK OUT WINDOW BLINDS PREVIOUS: 54 CORSA 1.3CDTI SXI - WRITE OFF ![]() 05 MICRA 1.2 16V SE - IN PURPLE - PART EX ![]() | ||
| | #7 | ||
| | #8 | ||
| | #9 | ||
| Pick a window,your leavin | Re: Cigar Lighter Change It's useful though, it means if I want to charge my phone, headset, sat nav whatever I can sling it in the glove box so no trailing cables everywhere.
| | #10 | |||
![]() the stilo needs a secret coin storage place. near the gearstick isnt good enough, and if you load it up some of the coins fall out ![]() my micra used to have a little pull out drawer just below the cd player
__________________ FIAT STILO..... ABARTH IN DISGUISE ![]() SCORPION BADGES, SKYROOF, 17" ANTHRACITE BLADES, ABARTH SIDE SKIRTS AND SPOILER, BLACK OUT WINDOW BLINDS PREVIOUS: 54 CORSA 1.3CDTI SXI - WRITE OFF ![]() 05 MICRA 1.2 16V SE - IN PURPLE - PART EX ![]() | |||
| | #11 | ||
| It's about GO! not SHOW! | Re: Cigar Lighter Change As Chris has said it's much neater and more practical if you add an adapter. Here's mine down by my left feg. ![]() My coin holder is always full and coins never fall out. You don't want instructions on what coins to fit do you
| | #12 | ||
| Dislikeskeyboardwarriors | Re: Cigar Lighter Change
__________________ | ||
| | #13 | ||
| loves you lots ;) | Re: Cigar Lighter Change i hardly ever use the coin tray, always have my wallet on me
| | #14 | ||
| *custom name* | Re: Cigar Lighter Change yea i wudnt mind changin this myself? see the one from Fiat, is that just a replacement for the actual charger itself, you have to use all the original trim i presume? i like Chris's idea, i mite do that as phone charger and sat nav tucked away neatly wud be nice for me thats my Subway cupboard it fits a 12" beautifullytho i have had this problem with coins of the fallin out quite a bit, problem is, when they fall out they fall on the subframe of the seating and my guess is that something is stuck in the release for the seat, cz it doesnt slide foward nemore when i pull the lever to tilt the seat foward (3 door) bt it does slide foward when you pull the tab under the seat up, weird one
__________________ 1.2 3dr stilo dropped on claws & a suzuki bandit v | ||
| | #15 | ||
| Pick a window,your leavin | Re: Cigar Lighter Change I had one of those splitters in the same place Argo, but this plug kept falling out, and it meant I couldn't use the lighter (I'm a dirty filthy tabbing b*st*rd ) so I opted for the hardwire approach. Wasn't difficult at all, hardest part was getting the cable through the bulkhead when I fitted my sub. Took the sub out after the amp drained my battery and used the live feed for the auxilliary fusebox in the upper glove box.
| | ChrisMClark | Stilo | 6 | 05-04-2007 10:34 |
| | Mr c | Marea | 5 | 20-01-2007 22:34 |
| | ChrisHGT | Punto | 8 | 08-10-2006 17:55 |
| | bjelivuk | Marea | 1 | 14-08-2002 20:41 |
| | bjelivuk | Bravo / Brava | 0 | 05-08-2002 16:45 |
