DeanF
After i bought my Stilo 1.9 Jtd (73K Miles) i noticed a clunk from the Near side when taking up drive in 1st & 2nd gear (Not always though) Since i have done a few hundred miles this seems to be developing ! I noticed it tonight whilst coasting over speed humps. So when i got home i took the N/s front wheel Orf (Thats the posh way ) & had a look. I could see Grease thrown about on the gearbox casing ! , I thought Hmm Cv gaitor has split , It has not, But does look like it has been replaced at some point as it is different to the outer & is held on with a Zip tie ( Not a metal Clip)
So i grabbed the Shaft & rotated the wheel, The noise could be heard, If you rattle, Push, pull & rock the innner Cv it also makes the noise & there is quite alot of play there, SO me thinks this is the cause of my knock/noise.
Does anyone have a rough price for a recon shaft or a CV coupling ?? & do you think my diagnosis is correct ??
Dean
Dean
