| SW Stilo Rear door handle switch operates as rear glass switch As it says in title and my switch for rear glass doesn't work. From the remote everything works OK
| Fiat = Ticking BOMB! | Re: SW Stilo Rear door handle switch operates as rear glass switch So when you pull the boot handle/bar the glass opens?
__________________ If my reply has helped you please give me a (03) Fiat STILO JTD[115 + ●Red-Dot● Magic!] Multiwagon Dynamic - 1st ever Fiat (God I hope I made the right choice! )Please don't complain about my spelling | ||
| | #3 | ||
| Re: SW Stilo Rear door handle switch operates as rear glass switch exactly, ain't that wierd?
| | #4 | ||
| Fiat = Ticking BOMB! | Re: SW Stilo Rear door handle switch operates as rear glass switch Wierd! what happens when you use the switch for the glass? Sounds like an electrical glitch, maybe shorting somewhere or water in the boot lid? Does your rear water squirt work?
| | #5 | ||
| Re: SW Stilo Rear door handle switch operates as rear glass switch I think it does, but window switch or pad is dead. I'll try to disconect it from battery and see if it resets. I t must be two way motor that unlocks window when pressing its pad and rear door when catching the handle. I hope it is not infected by bad luck happening to Fiat electronics, as i heard WD40 is the cure fro any bugg
| | #6 | ||
| Re: SW Stilo Rear door handle switch operates as rear glass switch WD40 rulz, it cures AIDS - at least I heard so...
| | #7 | ||
| Re: SW Stilo Rear door handle switch operates as rear glass switch imas na b92 automobili diskusiju o jtd stilu i nacin kako da skines manual na srpskom sorry guys for writing in greek, found my countryman. Problem solved.Glass switch which is assembled on the num.plate lights got some moist and @##$#$$%$@#@boom,took the part off, cleaned contacts and thats it
| Tags |
| problem, rear door, switch function |
| | dalemultiwagon | Stilo | 13 | 29-04-2006 21:10 |
| Die Hard!!! | The Negotiator | Leisure Lounge | 27 | 24-04-2006 22:20 |
| | Legsakimbo | Stilo | 29 | 01-11-2005 19:59 |
| | danielson81 | Cinquecento / Seicento | 2 | 11-10-2005 23:33 |
| | Body Stylist | Punto | 30 | 09-04-2005 17:02 |
