The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 09-12-2007   #16
Falling Into A Trap
Joshua Frost-Lunn's Avatar
Trader Rating: (0)
Joshua Frost-Lunn has donated! United Kingdom
Re: sky roof puzzle.
didnt use mine today in the end
drizzly rain for about 5 minutes, followed by quite a downpour
JOSHUA FROST-LUNN STILO
Joshua Frost-Lunn is offline
Old 10-12-2007   #17
TejmaLee's Avatar
Trader Rating: (0)
Yugoslavia
When I'm opening my roof blind (skywindow curtain), it starts going smoothly but then after few cm stops than jumps backwards, than goes 20-30cm smoothly than again stops and after a second jumps back again, and finally goes smoothly till the end!!!
You can hear motor pulling it backwards but looks like winding or something at the back is making it stops.
Any help?
2002 Fiat Stilo 5dr 1.9JTD Dynamic, Silver Metalic, Full plush interior, Sky Window, 16'' alloy rims, Pirelli P7.
TejmaLee is offline
Old 10-12-2007   #18
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
I presume you've given the runners a good clean?
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 11-12-2007   #19
TejmaLee's Avatar
Trader Rating: (0)
Yugoslavia
I did cleaned them, but it didn't help much.
TejmaLee is offline
Old 17-12-2007   #20
ABZSTILO's Avatar
Trader Rating: (0)
ABZSTILO has donated! United Kingdom
Check the trim that goes around the inside of the roof lining for the skyroof, this sometimes 'flicks up' (it's not the best fit) and can catch the blind causing the symptoms you describe.
'03 JTD Dynamic Grigio Steel with skyroof, Eibach -30mm pro-kit, Abarth shadow chrome 16" alloys with Vredestein Sportrac 3 boots, OMP strutbrace.
Red Dot Racing remap and modified GSR induction = 155 BHP
ABZSTILO is offline
Old 18-12-2007   #21
TejmaLee's Avatar
Trader Rating: (0)
Yugoslavia
Hmmm, now I'm not sure if what I'm doing is right.
I have checked and cleaned left and right "runners" that curtain is sliding along as "Argonought" is mentioning. Or what I was thinking that was! Now, I'm puzzled is "trim" that ABZSTILO is talking about the same thing? Or there is something more than small "canal" that curtain slides trough?
Did I mentioned that it started flicking at only one place (way back close to the end) and now flicks also at the middle.
Hope, I'm not too confusing... Ignore me if I'm boring with this.
TejmaLee is offline
Old 19-12-2007   #22
Trader Rating: (0)
another update...
if you push down the dial it clicks and kinda locks the skyroof. it completely cures the rattle, however the dial doesn't open the roof, nor does the blind move until you press the dial in again..
is this the way it's supposed to work? I don't have a users manual so completely in the dark.
jayteedee is offline
Old 19-12-2007   #23
Argonought's Avatar
Trader Rating: (0)
Have you read this thread?
Old 19-12-2007   #24
Trader Rating: (0)
ah... so when i push the dial it goes to "hard close" which means the rattle stops but the dial is inactive. To open it again you have to press it down to switch it to "soft close" again, and you get the use of the blind/dial.
is that right? does everyone else use a "hard close" when the roof is shut for a long period?
Old 19-12-2007   #25
Falling Into A Trap
Trader Rating: (0)
ive never used the hard close feature on mine, i dont think ive ever pushed the dial in
Old 27-12-2007   #26
Trader Rating: (0)
had same with a jtd, went back over 8 times. they said they could not cure it (Perrys Huddersfield) Due to other things they took the car back. Now have an Abarth that had same noise, its the workings above the rear pasingers heads slightly coming slack. Took it to Clemos in cleckheaton and they solved it with packing everything with pipe insulation so parts did not vibrate and it has cured it. You have to take all the roof lining out to do it.
fueltank is offline
vB code is On
Sky Roof Not working! DubWitStilo Stilo > Technical 47 21-09-2006 13:19
Cleaning the Sky Roof Argonought Stilo 0 05-08-2006 16:41
repairing stilo multiwagon and fitting sky roof !!! dalemultiwagon Stilo 6 08-05-2006 11:53
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 21:20
sky roof stopped working pekinghunchback Stilo 1 15-12-2005 13:57
