| Overboost valve name? Hi! I have read all threads related to overboost valve problem, and I'm sure I'm one of lucky guys with Stilo that suffering from poor overboost valve design. I'm going to move it up to battery try, and I want change it by myself. Questions: 1. what is technical name of overboost valve - wherever I try to find no part with that name. 2. should I just replace it by myself (we have just one dealer, extremely expensive and with no much knowledge)? Thanks in advance
| | #3 | ||
| It's about GO! not SHOW! | Re: Overboost valve name? It's well worth taking some effort to find some really good tubing to accomplish the move. I checked with my dealer to see if a 'transfer' pack might be available but it would seem it isn't so you'll just have to buy the tubing yourself. I say this because many converted JTDs, after a year or so, can experience overboost faults due to the new tubing starting to split
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #4 | ||
| performancestilo.co.uk | Re: Overboost valve name? | ||
| | #6 | |||
If these are original tubing then they wont be much use unless they're quite long and you have to cut them to size. In that case they might be just the job
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #7 | |||
will looke again to be sure. i thought you would have to just cut to size. they are definetley longer as opposed to shorter. edit: my bad, i have found this 55203202 - ELECTRO-VALVE replacement for 55188059 doesnt give a reason for the change though. change date 04/2006also 13000190 for a collar that is needed to connect the pipes to the valve but the pipes have the correct codes as above. Last edited by stilosporting; 21-08-2007 at 21:32. | |||
| | #8 | ||
| Re: Overboost valve name? Hey guys, I’m totally confused. T1406 told that it is overboost valve. On ePER part no 55188059 is electro valve, on some Czech site I found beside that part number that it is EGR valve. I think EGR valve is something different than overboost valve? Anybody know how to ask for part in shop? From other threads, I didn’t understand if just putting it on battery box is enough even if part caused fault, or it is necessary to replace it and move it to the top?
| | #9 | ||
| It's about GO! not SHOW! | Re: Overboost valve name? Move it and give it a good clean at the same time. Only replace it as a last resort (normally suffers from getting wet!). You should be able to see what it looks like from various images posted on the Forum. As you say, it's certainly NOT an EGR valve and is actually really quite small. Well, I'm sure you can look for yourself
| | #10 | ||
| | #11 | ||
| | #13 | ||
| The modfather | If you think its crap then give us the details so we can log into and get the same info as you techs do when working on cars in the work shop now that would be use full to say the least Eper for what it is has its uses and a darn site better than nothing at all
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. | ||
| | #14 | ||
| | #15 | |||
| Grumpy Forum Moderator | Re: Overboost valve name?
compared to other manufactuers systems its s*it
__________________ IF YOU'RE HERE TO MOAN OR SLAG FIATS - DONT BOTHER! | |||
| | BoostGT2 | Punto | 6 | 15-01-2007 19:54 |
| | the beasto | Cinquecento / Seicento | 52 | 18-05-2006 10:30 |
| Turbo overboost valve? | multipla-aire | Multipla | 11 | 07-08-2005 18:46 |
| All FIRE engine cam specs needed | smokeme | Lets Talk FIAT | 5 | 01-08-2005 09:50 |
