General Fiat Stilo Abarth 2.4L 20v Turbo!
if you have the manual gear box you have many choises
but you mast find the flywheel -cluth -gear box
and it fit form Lancia thesis 2,4 20v .
Thanks for the info. Food for thought! Tell me, do the original gear cables and linkages tie up OK? And what about the gearbox to body mounting points - do they line up?
no my gearbox is the manual .
but in my other project all the selespeed gearbox will have two opsions
1. make it more racing with final 3,97 / 1 from 3,57 / 1
2. or make it 6 gear selespeed with it ECU controling original 6 gears
but for 1000% quarante answer please wait until I am finish this project
Hello stilodriver!
How do you make alterations to the Selespeed ECU?
Can you make selespeed change gears faster?
thanks!
Hello everytone...This is Gökhan from Turkey..i've got a Fiat Stilo Abarth 2.4 20VT..just started to make it turbo...does anybody know which car's or where can i find a forged pistons for my abarth? i need 83.040mm...
i will show you the details or you can check my webpage below...
facebook. com/groups/abarthgarage
here is my Turbo List..
16G TD05 evo9 Turbo...Tial 44mm Ext.Wastegate...Tial 50mm BoV...
560cc Evo9 injections...fiat coupe 20vt fuel ray...Fiat Coupe 20vt engine cover...fiat coupe 20vt port polished inlet manifold...fiat coupe 20vt exhaust manifold...15Row oil cooler...8.5lt intercooler...Aeromotive 340lph internal fuel pump...ecumaster emu classic with bt...greddy profec evc...aem wideband 4.9...aem x oil press...aem x egt...no rear seats...front rear and bottom strut bars...100Ahm battery...new and more strong power and ground cables 50mm...R8 red coils...ngk bkr9eix spark plugs...bronze clutch kit...and so many things i will thinking to do in time...and i am expecting about 300hp and i do not want more...
