| my stilo keeps flashing up that firstly my asr has failed then my power steering has failed then i have an engine fault n a loose connection but everything seems to work ok is it the stupid conmputer its still under warranty so going to the garage on wed but wondered if you knew what was wrong so i know before they look at it thanks x
| It's about GO! not SHOW! | Re: bloody thing There's enough on the Forum to keep you going all evening on that lot. Use Search and you'll find stacks of suggestions.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #3 | ||
| Re: bloody thing I think that sounds like a damp D4 to me! Drove through any big puddles lately?
__________________ | |||
| | #4 | ||
| popping out | Re: bloody thing I like guessing what warning message I'm gonna have next so far I've had, ESP/ASR failure, ABS failure, gearbox failure, engine fault but all is fine in Stiloland
__________________ MR2 owner!!!!!!! | ||
| | #6 | ||
| Re: bloody thing my best set off error messages was when it was -6 degrees outside and the car gave me more or less every warning message, even for stuff my stilo doesnt have!
| | #7 | ||
| The modfather | Get your battery checked out as low voltage can bring up error warnings on a regular basis ..also have a look at D4 connection [located under the fuse board on the battery] if its wet or dirty this can give all manor of problems ..
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. | ||
| | #8 | |||
| Re: bloody thing
__________________ Black 115 JTD, 15' Steelies with Doblo trims & debadged +147 Cruise Control NOW with added Millers Diesel Power Sport 4 | ||||
| | #9 | |||
with mineThink I'll keep him till he's at least 5 years old
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #10 | ||
| Re: bloody thing cheers guys will take note so where do i get an undertray from? im a useless women n dont have a clue x
| | #11 | ||
| It's about GO! not SHOW! | Re: bloody thing I wouldn't worry about the undertray too much (you may never have had one in the 1st place). Best thing is to work on hints already given or give us a bit more info to go on
| | #12 | |||
| Back once again w'the... | Re: bloody thing The 'D4' reference above is to a large connector that lives in the battery area. Check the Stilo guides/sticky messages. Maybe for starters, just remove the battery and hook up to a battery charger, leaving it overnight. Then clean the battery terminals - you can get a special round wire brush that makes this easy. I've had some false alarms also for ABS/ASR/ESP, which turned out to be the low battery voltage. 'Loose connection' though is likely to be the D4. If it seems like there is dampness around the battery, then clean the D4 connector with electrical contact cleaner spray and dry out with a hairdrier or similar. Deckchair5 has a method of sealing it in a plastic bag, but generally if you have a battery cover fitted, it shouldn't be getting too wet. Cheers, -Alex
| More bloody thieving chavs! | JonnyBoy | Leisure Lounge | 11 | 19-05-2007 11:26 |
| | jug | Bravo / Brava | 37 | 06-05-2007 00:39 |
| Bloody squirrels | allanhelen | Leisure Lounge | 6 | 10-04-2006 23:14 |
| | alfanige | Stilo | 4 | 29-05-2004 03:46 |
