| Oil Pressure Problem Right, another problem straight away, Im beginning to regret buying another fiat after my bravo. Anyway, When I start the car and leave the car ticking over the revs are slightly fluctuating from anywhere around 700-1100rpm, Then When I rev the engine and let it drop to tickover again, the revs drop to anything from 100-900rpm, and sometimes it cuts out.. says low oil pressure, but then when I start it back up again, its back to 700-1100 fluctuating. when its warmer it seems to sit better at 950-1000 slightly wobbling. Anyway I drove the car back from Lincoln, as I only bought it tuesday, and i revved it on the guys drive, with none of the this oil pressure, sure, the revs fluctuated slightly, but nothing out of the ordinary. Only thing Iv've done since is top the oil up. I thought that that could have contributed to it, as 0 problem before, 1 after. So tonight I put new Oil, Air Filter on, and also completely changed the oil, very good oil aswell, Stuff they use in the Ferrari's (As I work in a garage). It didnt change and it gave the same problem, but when I got a charge hand to show him, I revved it 4 times in a row and the revs dropped, but it didnt cut out or show low oil pressure. Anyone got any idea what could be causing this? Cheers, Andy. Edit: There are no problems when driving, drives perfect. No abnormal noises or anything.
| Whaddya mean too old? | Re: Oil Pressure Problem Ha! Looks like you'll be working your way down the Stilo Guides one at a time! Sounds like your inlet valve needs cleaning- look in the Stilo Guides for how to- same as the Bravo really Have you told us what engine you have? If so i missed it. Stilo engine should tickover at rock steady 800rpm when warm. Oil pressure warning will just be the low revs and stalling I'm guessing so cure one cure all probably Once you've done that disconnect the battery for a few hours to reset the ECU and let it relearn what's best-again, same as the Bravo. See it's handy staying with the same make of car
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 13-07-2007 at 20:03. | ||
| | #3 | ||
| Re: Oil Pressure Problem Right so ive established that its not actually a low oil pressure at all, its simply the revs are dropping so low, its reading a low pressure, with aircon on it holds it up just enough to not want to stall or anything, but im not leaving that on forever. I cleaned the inlet butterfly (which was clean as new anyway) and it didnt do anything at all... what else could be causing this problem? cheers. I didnt actually have this problem when i got the car on tuesday, I drove all around from lincoln and everywhere 50 odd miles, it only happened wednesday night when, and even then all id done was the airbag fix.. and had the battery disabled while i cleaned the plugs. Any Ideas?
| | #4 | ||
| Whaddya mean too old? | Re: Oil Pressure Problem Yes the oil pressure is just a symptom of low revs You cleaned the inlet valve before or after the problem started? You disconnected the battery and the problems started happening afterwards yes? What engine size? What gap on the plugs? I reckon 0,9mm to be best for the 1.6 Sounds like your ecu has lost track of the throttle body OK start again. Disconnect the battery for a few hours to reset the ECU again and then do a throttle body self learn reset. What's that? Don't touch the throttle, brake or clutch throughout any of this procedure Turn the ignition on but don't start the car Leave it for a minute Don't touch the throttle Turn ignition off Wait another minute for it to shovel the info into the ECU Now start up and just do a normal drive for 30mins If it's still not playing ball then give it an Italian workout of some high revs when stationary Keep us posted
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 13-07-2007 at 23:02. | ||
| | #5 | ||
| Re: Oil Pressure Problem thanks for the advice, the engine size is 1.8 16v by the way (damn i love it when it drives) and i wont be able to do a normal 30minute drive for a while as im booked in for cambelt on wednesday, i know its cutting it close, but ive done 73k and cambelt is at 74k, so im only traveling less than a mile a day untill wednesday. Its having cambelt done, and im going to get the garage to check the throttle anyway, but afterwards im going to do as you posted. cheers mate, ill update you.
| | #6 | ||
| Re: Oil Pressure Problem I did the reset and it worked a treat, the revs aint dropping it it no longer cuts out, cant wait to get my cambelt done on wednesday and give it a proper italian drive >: ) by the way I notice you have a 1.6 litre stilo how would you rate the driving I mean as in, what can keep up with you and what is your stilo faster than etc.. in general road use. As Ive gone from a 1.2 80bhp bravo to a 1.8 stilo 133bhp, i feel a difference aleady.. although I do want it remapped.. But i noticed 6bhp from GSR? what??? Why dont angel tuning do the 1.8 stilo, as they did my bravo and i noticed the difference.
| | #7 | ||
| Whaddya mean too old? | Re: Oil Pressure Problem Good stuff I should think you would notice the difference from a 1.2 Bravo to a 1.8 beastie Maybe pop over to Performance Stilo site for friendly tuning advice. The 1.6 and 1.8 can be remapped but it hasn't been so easy as the others.
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #8 | ||
| The modfather | You will notice the difference with the induction and mapping done on the 1.8 its quite a gain on the both cars ..my 1.6 is now running at 121.4 bhp from the 99.9bhp it disappointingly ran on the dyno and since its been done I think it has even improved on that figure now the ECU has fully releaned
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. | ||
| | Shminkypinky | Stilo | 6 | 02-07-2007 10:44 |
| | jmac | Stilo | 6 | 25-06-2007 13:33 |
| | Alphaville | Cinquecento / Seicento | 4 | 15-05-2007 14:13 |
| | cinq117 | Cinquecento / Seicento | 6 | 17-01-2007 12:06 |
| How do perform an oil pressure test | andymanmusic | Lets Talk FIAT | 2 | 09-03-2006 19:51 |
