The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 10-07-2007   #1
Trader Rating: (0)
Connect Nav+ Fault
I have an 02 Abarth with the connect Nav+ fitted. Bought the car in 03 and have had no problems except the high cost of Fiat servicing.
However since buying the car the sat nav unit will not work when the car is up to temperature, it also will not read mp3 cd's. I just get the message "CD Error". It is fine when the car is cold. When you put your hand on the unit it is quite warm. The software is up to date.
Anyone out there any ideas please.
MATOPPING
MichaelTopping is offline
Old 16-07-2007   #2
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Re: Connect Nav+ Fault
Hi there - how nice to hear from a long-term owner who has not had problems
Does the Connect Nav+ read audio CDs OK when it is up to temperature?
If so, then I suggest trying a high-quality CD (i.e. an expensive one) with the MP3s written using Windows XP (!) I find that under Vista, iTunes writes a CD that my Connect Nav+ just gives CD ERROR for.
Incidentally, Connect Nav+ has a fan in the back of it - I can hear it running after a couple of minutes with the music on and the ignition off. If you can't hear yours running, perhaps it is worth pulling it out and checking/cleaning the fan? I can imagine that if the fan is a common PC-type fan, and if it has seized, then the unit would be getting hotter than usual?
Just a couple of ideas, sorry I can't promise a fix...
Cheers,
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Tags
cd error, unit to hot
Need a New Connect NAV + ? myworlduk I.C.E 1 19-06-2007 19:01
Fiat Connect Nav + x2 On Ebay Bubble18-30 Auction Watch 1 03-05-2007 13:11
(T) i need a connect nav disc stilophil Stilo 5 15-07-2006 20:57
(T) how do i connect a sub to connect nav + scrod Stilo 3 24-02-2005 16:16
Connect Nav - How do I Play[?] Gladiator111 Multipla 1 06-07-2003 00:22
