| Changing Front Brake Discs Hi, Can any one tell me how easy it is to change the front discs on my Stilo JTD? Also can any one recomend a better price of £60 for 2 discs and pads? Thanks in advance
| __________ | Re: Changing Front Brake Discs tis easy, calipers and carriers off, disks off, new disks on, caliper carriers back on use thread lock on bolts, fit pads to calipers and carrier use copper grease on metal bits that rub, re fit caliper. £60 is the right price.
__________________ Binki | ||
| | #3 | ||
| The modfather | Short and sweet eh Dave I think I did a more detailed one for Chris Clark ..have a search and see if you can find it
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. | ||
| | #6 | ||
| Re: Changing Front Brake Discs £54 for mintex brakes on ebay, the disks are good the pads are a bit hard for my liking, just got some Green Stuff pads for the front, gonna put them in when the sun comes out... if it ever does... far too wet out there at the moment. Changing the disks is an easy job, 3 bolts not including the wheel nuts. 7 in all! Jack it up (pref: 2 tonne jack) place wheel under the side of the car 4 bolts on the wheels, taken em out... take wheel off 2 bolts on the back of the callipur... (theres only 2 fairly large sized bolts on the back... the same size vertical to the wheel arch) you might have to give the ratchet arm a smack with a rubber mallet with these. Dont forget to tie up the callipur (i usually tie it to the suspension spring with some wire but good string will do the job) as to reduce stress on the brake hose. DONT let it hang on the hose alone! 1 odd little bolt on the front of the disk... its a wheel mount positioner nut by day... but by night it holds your brake disks on... take that out and the disk comes off (Advice... try to get pads with rubber backing pad... this will illiminate brake squeel) Mintex dont have the rubber pads, but like i said the disk are good enough. Changing the pads as you go is easy, whilst the callipur is tied up prise out the pads from the silver couplings. To get the new pads in with enough gap to allow for the new disk loosen the brake fluid reservior cap under the bonnet and push the callipur back into the housing. (the front callipur pushes in unlike the rear which rotate in) Reasembly is the reverse of this. You may find it a little fiddley getting the pads into the silver couplings but you can do it. Took me about 30mins a wheel at a casual pace on a sunny day.
__________________ Fiat Stilo 1.6 Dynamic 3 door 02' Black | |||
| | #7 | |||||
| Pick a window,your leavin | Re: Changing Front Brake Discs
Dead easy to do, but certain bits can take some, ahem, 'gentle persuasion'. With a mallet. A big f*cking mallet. A rubber one.
| | #8 | |||
| The modfather |
and @ mortgage man click on the link on the bottom of my post and view the brakes section I have just written a guide for replacing the discs and pads on a jtd ..veiwing is free and none obligatory ..
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. Last edited by PNL; 28-06-2007 at 22:43. | |||
| | #9 | ||
| Pick a window,your leavin | Re: Changing Front Brake Discs The mallet was for the nosy little Nova driving Chav scrotes who seemed faciated by a bit of mechanics work...either that or they were eyeing up my shiney tools in my shiney red tool box. oh, and to loosen off the old discs
| | #10 | ||
| Brain freeze | Re: Changing Front Brake Discs I've got the Mintex brake package on the front and they squeal like a banshee when warm. Still, damn good stopping power and I dont care if they are noisy. Surely there is a market for vulcanised self adhesive rubber anti squeal backing stickers open for abuse.
__________________ Stilo JTD 115 3dr Dynamic 2002 with Skyroof, 16" Alloys, in Pitti Blue. No mods........yet | ||
| | #11 | ||
| Pick a window,your leavin | Re: Changing Front Brake Discs Or out of date jonnies and pritt stick off to raid boots and our office stationary locker I had serious squealing problems with Quentin Hazel pads. Wouldn't have been so bad if they were half decet pads...how they got their kite mark I'll never know.
| | #12 | ||
| Brain freeze | Re: Changing Front Brake Discs Apparently you can buy anti squeal kits. So the market has been catered for.....damn there goes my money spinner. I was going to make a stainless steel shim with a solid rubber backing that could be bonded on to the pad. Just when you come up with an idea, you always find someone has got there first. BAH!
| | #13 | ||
| Re: Changing Front Brake Discs I got some red rubber in a sqeezy bottle from the states made by siloo for stopping brake squeel. You squirt it in the rear of the pad and let it dry... it worked for about two hours then the squeel back it came. Total waste of £3.50 One more star on my ebay account tho.
| | #14 | ||
| Re: Changing Front Brake Discs Thank you very much for your help, i can't beleive it's that easy, i thought i was missing something? Thanks a million. If you ever need help getting the best mortgage deal on the market, drop me a PM [BUSINESS EMAIL REMOVED BY MODERATOR] Many thanks Graham
| Replacing Front Discs | Gaj | Coupe | 8 | 10-10-2006 21:32 |
| Die Hard!!! | The Negotiator | Leisure Lounge | 27 | 24-04-2006 22:20 |
| | Ems | Punto | 3 | 02-08-2005 07:38 |
| changing the front speaker wire | Dan_55 | I.C.E | 6 | 01-01-2005 20:28 |
