Basically, it's done like this:
- Loosen the wheel, and loosen the nut on the suspension strut in the engine bay.
- Jack the car up.
- Remove wheel.
- Remove the two bolts holding the strut onto it's carrier.
- Remove the nut securing on the antiroll bar drop link (think this is 16mm).
- Remove the nut in the engine bay.
- Lower the whole unit out of the suspension turret
- Use a spring compressor to compress the spring, and remove the top strut bearing/mount.
Refitting is the opposite.
I'm still getting a knocking coming from the front suspension when going over bumps (mainly on the right hand side of the car) after changing both drop links. Can the top strut bearing/mount cause knocking? Are they replaceable?
If not, what else could the knocking be? (might start a new thread!)
The end of the steering rack perhaps. Top mounts are replaceable. Don't think the top mounts can produce "clonks" as it is a loose fit to the turret.
For removal (with picture description), refer to the guides section on this very forum.
Morten.
Thank you Dave
Out of interest, why are you asking, Ballack? Got problems with the top mounts? Knocking noises or something?
