| Hi guys, I’ve decided I can no longer live with the soft woolly handling of my 1.6 Active Sport 3 door so I’ve decide to fit some new shocks and springs. The consensus seems to be to go for Eibach -30mm springs and the pro dampers. What sort of price will theses come to for front and rear? Where’s the cheapest place to buy them from? Also, will these really make a different in improving the handling of the car? I’m still deciding if I should just get the springs and not bother with the shocks? Also, do you guys think I should try fitting a strut brace first before I do the springs/shocks to see if that improves that handling up to a decent level? Cheers Matt
| It's about GO! not SHOW! | Re: Handling Improvements As you have a 1.6 (east to fit) then I'd go for the strut-brace 1st.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #3 | ||
| Italian Stallion | Just go for the Eibach springs, designed to work with your standard shocks, do the job, notice the difference, the best £90 you'll spend.
__________________ The Stilo Has Now Been Sold! | ||
| | #4 | ||
| Re: Handling Improvements If you are lowering by 30mm and retain the original shock absorbers, you may notice increased wear in them and they will fail sooner than expected. Reason for this is that they will have to perform the same amount of work (ie damp the spring occilations) in a shorter travel distance, which means higher forces applied to the device. You may want to replace the springs and shock absorbers as a matched pair.
__________________ Ciao - 1.6 Fiat Stilo, Konnichiwa - 2004 Mazda 6 2.0 D(137) TS. 2004 1.8 Vauxhall Vectra - 5 Door 1974 3.5 V8 Triumph Stag - 2 Door | |||
| | #5 | ||
| It's about GO! not SHOW! | There also seems to be increasing evidence that changing to sports shocks and keeping original springs may offer better results than only changing the springs (obviously this wont change the look of the car)
| | #6 | ||
| The modfather | That's correct just changing the springs wont give you the absolute answer and as Steve has said your shocks are living on borrowed time due to the piston being compressed to a lower setting and travel restricted sports shocks have a shorter piston rod to go with the shorter springs ..people also need to realise that when you lower your car you also alter the track setting and steering geometry so make sure these are done as well or abnormal tyre ware can take place
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. Last edited by PNL; 04-06-2007 at 16:20. | ||
| | #7 | ||
| Re: Handling Improvements OK, thanks guys. I'm being a bit lazy but what sort of prices are we looking at for each option? Strut brace Springs only Springs and shocks That may give me a better idea of the cost-benefits of each option. I think I would like to go for springs and shocks, as surely springs only cant really improve the handing that much, I would have though that its more for looks than anything else? Cheers
| | #8 | |||
| The modfather |
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. | |||
| | #9 | ||
| Re: Handling Improvements strut brace eg http://cgi.ebay.co.uk/OMP-Front-Stru...QQcmdZViewItem Don't know if these are good, bad or indifferent
| | #10 | |||
__________________ Phil Thomas Yellow Peril Then:Yellow Stilo 1.6 16V 3-door - not quite standard ![]() Now: Red Stilo Abarth Schumacher GP Prodrive | ||||
| | #11 | |||
You need to stop telling people Eibachs are £90!!!! They are nearer £150 although PNL can get 5% off (he says in his post). If you want ultimate handling then you need a full coilover set up, but for road use a set of lowered springs will be an improvement...... These are PI springs.....not bad....I have them and they are an improvement. http://cgi.ebay.co.uk/Brand-New-FIAT...QQcmdZViewItem This would be better still - http://cgi.ebay.co.uk/KONI-SUSPENSIO...QQcmdZViewItem if you really want to sort the wooliness, sell the Stilo and buy something with a better chassis!!!!
__________________ Its all about go, not show Last edited by alpinepg; 04-06-2007 at 22:27. | ||||
| fiat coupe handling | jolly458 | Coupe | 7 | 13-10-2005 09:46 |
| Small old Fiats with good handling | dreedraffs | Lets Talk FIAT | 1 | 28-07-2005 06:18 |
| Handling Packs for Doblo's | Dobbytastic | Doblo | 5 | 25-06-2005 09:35 |
| | cazz | Bravo / Brava | 1 | 14-04-2004 16:51 |
| | SteveH | Bravo / Brava | 3 | 14-03-2004 23:55 |
