The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 02-04-2007   #1
2.4 abarth in front
lee gagg's Avatar
Trader Rating: (0)
lee gagg has donated! United Kingdom
Engine Fault - Rough Running
Hi guys just driven home from work and my car (2.4 abarth) displayed this warning ENGINE CONTROL SYSTEM FAILURE.Now it drives like a bag of spanners almost like its running on 4 cylinders so i suspect a coil may have gone down.Ok how do i proceed from here please car parked up at mo.The coils i have say bosch on em so i assume that be the thing im looking at.Not much of a car expert but looks easy enough too replace.Oh also how do i determine which one it is as there is 5.All help greatly apprciated.Car has done 26k and i have noticed it sometimes kangaroos a bit when cold so this could point to it being a coil.
The car in front is a stilo 2.4 abarth The car thats left you for dead was a stilo 2.4 abarth
lee gagg is offline
Old 02-04-2007   #2
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Re: urgent help req
There are quite many topics regarding the coils. Try the search funciton.
You can remove one lead from one coil at a time while engine is running. No high voltage before the coils. If the engine changes behavior, you can rule out that one. If nothing happens at coil no.4 (as an example) this is the worn out one.
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 02-04-2007   #3
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: urgent help req
Also there will be a distinct smell of bakelite/plastic from the one that duff so if you want you can take them out one by one and have a good sniff at them Take off your engine cover ..disconect the conections to the coils {ONE AT A TIME] and undo the 10mm bolt holding on the coil and pull out a coil {ONE AT A TIME} that way you wont get any cables on the wrong connections
International man of mystery
Wit ..sarcasm you get it all from me..
PNL is offline
Old 02-04-2007   #4
2.4 abarth in front
lee gagg's Avatar
Trader Rating: (0)
Re: urgent help req
Ok update:Went outside and took off in turn starting from the left the connector to each coil.Each time the revs dropped and then picked up when i replaced them.Please note i didn't take the coils out.S hould i have too do that or will just taking off connector be enough.Also didn't noticed any funny smells of bakerlite either.I await more instruction.
lee gagg is offline
Old 02-04-2007   #5
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
Looks as though you have ruled them out then Lee
PNL is offline
Old 02-04-2007   #6
^ me
nightsmith's Avatar
Trader Rating: (0)
nightsmith has donated! United Kingdom
Re: urgent help req
Don't be takin the coils off with the engine running! You'll get yer conkers blown off.
From the sounds of it you did the test correctly.
nightsmith is offline
Old 03-04-2007   #7
2.4 abarth in front
lee gagg's Avatar
Trader Rating: (0)
Re: urgent help req
Latest update.Right guys as i speak my car is presently sitting in W.A.D (Wolverhampton Alfa Dealers) garage awaiting a diagnostic check tomorrow at a cost of £45 plus vat.
He said to me as i dropped it off that if the fault is found too be summat simple there will be no extra cost incured but he cannot say til check done.
Some of the alfa lads were well impressed with the car said you don't see many about.They got all the kit for doing the job and he tells me he got the ECU software update as well so i might ask him how much too do that if cost of repair not too high.I will post further news tomorrow night.Oh ps he said taking off the coils leads will also show as a fault on the check but he said at least we know too rule that one out.I got all my fingers and toes crossed.
lee gagg is offline
Old 03-04-2007   #8
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
Re: urgent help req
Thread name changed to something a little more appropriate.
Let us know the result!
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
Old 04-04-2007   #9
2.4 abarth in front
lee gagg's Avatar
Trader Rating: (0)
Re: Engine Fault - Rough Running
Hiya chaps.Well went too work this morning and at 9.30ish had call off garage.Guess what it was THE COIL no 4 too be exact.Got Bosch coils on mine.I knew it was a flaming coil but i did the test but nothing showed up but as the mechanic said it only failed broke down at higher revs and not when just ticking over which i must say i did notice that too.Anyway reults of my bill are as follows £45 for hook up to computer.£39 for coil from Fiat but i did ask which make he put on but he said it was just from Fiat genuine dealer so i will have a look at that and check.£21 for 1/2 hour labour for fitting which i thought was a bit of a con.I going away at weekend and with me being at work 7.30 til 5 leaves me kinda knackered too sort it myself really.So all in all i got my car back but it cost £123 for 1 coil but hey thats life.He did say they are prone for maybe more than 1 going well next time that happens i think i will do it myself.Cheers for help.Lee.
lee gagg is offline
(T) BEEP BEEP Engine Fault, becoming frequent ChrisF Stilo 35 31-03-2007 11:36
(T) Uno 70sxie rough running and stalling dodgem Uno 4 25-03-2007 11:28
oil - question for GC Hellcat Lets Talk FIAT 47 17-01-2006 13:54
(T) Engine fault Rayking Stilo 13 27-12-2005 18:39
Rolling roads figures, fact or fiction? J333EVO Lets Talk FIAT 18 01-11-2005 16:36
