The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 01-04-2007   #1
Pick a window,your leavin
Trader Rating: (0)
ChrisMClark has donated!
Help!
Could really do with some help. I've bought a Gunson 'Eezibleed' kit, but the instructions on the box are crap. As I understand it, you connect the bottle to the msater cylinder and a spare wheel to pressurise the syetem, then open each bleed valve 1 at a time. BUT how would I use this kit to drain the system and refill it? Really stuck with this one, and it needs doing desperately.
ChrisMClark is offline
Old 01-04-2007   #2
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: Help!
Aww come one, you're not trying
Take air out of a tyre until it's below 10psi. Put plenty of brake fluid in the Ezebleed reservoir, top up the master cylinder to the top, connect everything up, screw the Ezebleed top onto the master cylinder and bleed your old fluid out of each slave cylinder bleed nipple.
Don't forget to top up the tyre pressure again afterwards
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 01-04-2007   #3
Trader Rating: (0)
Re: Help!
Knew I could rely on you Decks
So how do you know when the old fluids out and the new fluids all the way in? Is there a distinct colour change?
Only reason I'm so dumb with this is I've never done it before! Also, I'm planning on changing my brake hoses at the same time, how does this affect the process?
Old 01-04-2007   #4
Deckchair5's Avatar
Trader Rating: (0)
Re: Help!
"So how do you know when the old fluids out and the new fluids all the way in? Is there a distinct colour change?"
Might be a colour change but probably not. You know how much fluid has gone in by the fact the Ezebleed bottle will be nearly empty. There's very little fluid actually in the brake lines as the bore is quite small. When you're fed up with buying new fluid then enough is enough
99 Bravo 1.2SX
Old 01-04-2007   #5
Trader Rating: (0)
Re: Help!
lol, fair enough. What about the hoses though?
Old 01-04-2007   #6
Deckchair5's Avatar
Trader Rating: (0)
Re: Help!
Same again, a very small bore so very little fluid in them.
NB You will need to syphon some fluid out of the master cylinder in the end to take it back to the max level from the "to the brim" full. Test your brake afterwards!
99 Bravo 1.2SX
Old 01-04-2007   #7
Trader Rating: (0)
Re: Help!
Sorry, I wasn't clear there. I mean what about changing the hoses (got some funky blue braided ones coming)
