The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 29-03-2007   #1
Ihatemyfiat's Avatar
Trader Rating: (0)
Ihatemyfiat has donated! United Kingdom
Stilo spar plug size
Sorry, this might seem a dumb question.
I plan to change my sparkplugs later and check replace coulpacks etc....do I need a particular size spark plug wrench/ spanner/ socket?????
Ihatemyfiat is offline
Old 29-03-2007   #2
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: Stilo spar plug size
There's only two standard sizes for spark plugs and the Stilo takes the smaller one. Need a deep socket and extension and one of these makes the job very easy.
Careful with tightening of course, torque it if you're not sure
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 29-03-2007   #3
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: Stilo spar plug size
A little tip for you peep as the plugs on 16 valvers are buried deep down ..
I use a length of thick walled rubber tubing to put the new plugs back in ..just push the plug into the tube and lower it down to the plug hole and then screw in to your hearts content finally tighten with a plug socket and extension bar /ratchet
International man of mystery
Wit ..sarcasm you get it all from me..
PNL is offline
Old 29-03-2007   #4
Trader Rating: (0)
Thanks PNL
Good tip, will a bit of garden hose pipe do?
Old 29-03-2007   #5
Trader Rating: (0)
Attachment 25979
thanks
Old 31-03-2007   #6
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
I always use a strong magnetic pick-up tool to lift plugs out
Great tip PNL - the aftermath of a crossed-thread in a spark plug hole is not worth remembering... uurrrgh... the helicoil thread-repair insert came out with a spark plug I changed once (on a FIAT twin cam) and things were never really the same again.
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 31-03-2007   #7
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
Originally Posted by Ihatemyfiat View Post
Thanks PNL
Don't see why not I found my piece in an old washing machine I was stripping down before I dumped it at our cleaning depo.. but as long as the ceramic section of the plug fits snugly on the pipe then it should be OK ..I use the pipe because I found that the plug socket had such a tight grip on the plug that when I pulled the socket off the plug after I had screwed it in the socket stayed on the plug and came off the extension bar so I took out the rubber insert out of one of the two plug sockets I have and it don't stay on there now I remove the plug with the socket that has the rubber insert and then screw the plug in so far with the tube and then tighten down with the other socket without the rubber insert
PNL is offline
Old 31-03-2007   #8
Trader Rating: (0)
Actually in the end, I bought a sparkplug spanner from halfords that was long enough and it had a rubber seal inside it that grips the sparkplug . Worked very well and cost about a tenner.
Old 31-03-2007   #9
Stilo_ste's Avatar
Trader Rating: (0)
Easy way to remove the plug if your socket's rubber insert is knackered is to totally loosen it and then push the coil onto the plug and lift out, easy really. Therefore you don't need any reaching grapper thingys
Ciao - 1.6 Fiat Stilo, Konnichiwa - 2004 Mazda 6 2.0 D(137) TS.
2004 1.8 Vauxhall Vectra - 5 Door
1974 3.5 V8 Triumph Stag - 2 Door
Stilo_ste is offline
Old 31-03-2007   #10
Trader Rating: (0)
simple but....Genious
Old 01-04-2007   #11
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Another tip when inserting the new (or removed plug). Put it in place, turn it against the clock (leftwise / counter-clockwise) until you feel a little snap in your hand. That is when the thread starts, and you can carefully tighten it 100% into the threads clockwise. Be careful, as making new threads in an alloy head is no fun.
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 01-04-2007   #12
Stilo_ste's Avatar
Trader Rating: (0)
I thank you !
(G) Dont Buy A Stilo rhyst Stilo 43 18-03-2007 14:21
(G) MK2 1.2 8V Oil Sump Plug Allen Key Size? melliottuk Punto 3 29-01-2007 16:16
(T) allen key size for sump drian plug? sps Punto 6 03-12-2006 21:09
(G) Stilo again? Maybe, maybe... DanU Stilo 3 20-10-2004 18:27
