The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 27-03-2007   #1
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Question Eibach TUV question / bump-stops.
I've now received my Eibach Pro System containing 4 sport shocks and 4 lowering springs (30 mm). The question is regarding the bump-stops.
As a point in the TUV papers, it states that the "series bump stops (rubber springs) must be kept" if using sport shock absorbers. As there were no special bump stops in the package, I suppose these are the original Fiat ones. Or am I wrong.
In another part of the TUV papers it says the bump stops should be the "original PUR bumpstops". PUR being polyurethane (difficult word). The data given in the TUV for these are:
Height/diameter (millimeter) front: 75/50
Height/diameter (mm) rear: 107/50-40
Are the Fiat original bump stops made of PUR? And does theses sizes make sense? I haven't removed the original shocks and springs yet in case I need to order new bump stops (Endanschlage). Are the "original PUR bump stops the actual bump stops on my car right now?
This is important when the car is shown for the proper authorities, who wear uniforms... If they find anything not thought of, I'll have some major problems, like not being allowed to drive etc.
I'd be happy for some bright ideas for this one. Will ofcourse e-mail Eibach aswell, but trying here first, as the forum members usually are a bit faster.
Regards, Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Last edited by Morty Mort; 27-03-2007 at 22:38. Reason: Forum can't handle German letters.
Morty Mort is offline
Old 27-03-2007   #2
Trader Rating: (0)
Re: Eibach TUV question / bump-stops.
If you use the original bump stops, I deffo recommend trimming off the amount the Eibachs are lower than the original springs (usually about 30mm). Otherwise you will be literally 'bumping' against the stops much more regularly which can adversely affect ride quaility. Wouldn't worry about the boys in blue though - the main thing is to let your insurance company know...
Phil Thomas
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive
Yellow Peril is offline
Old 27-03-2007   #3
Morty Mort's Avatar
Trader Rating: (1)
I had a feeling about the trimming, as I forgot this on the Uno when it was lowered. It was like there were 2 cm of spring play before the bump stop was struck. Remember doing a speed bump after mounting. I'm pretty sure the Uno was flying. Then it was put under the knife, and everything went well.
Regarding the car inspector boys in blue (who never managed to become cops)... These are the guys to worry about here. Not the insurance company. I've informed them, and I will have to pay exactly 100 NOK (about 8 GBP) for the Eibach Pro Set. I actually didn't have to pay at all, but wanted to be 100% sure everything was covered. The vehicle has to be shown for inspection after mounting and they follow the TUV paper's list of possible changes to the vehicle, being; lowering itself, lights, angles (camber/castor), brake pressure switch, wheel clearance, ride height, correct parts, bump stops, and more. Everything.
Morten.
Old 27-03-2007   #4
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: Eibach TUV question / bump-stops.
Polly parts arent available for the Stilo Morty so you cant fit them BUT as fiat do a great deal of parts sharing on their cars then it might be worth you looking at say the Brava/o ones to see if they are the same just a thought
International man of mystery
Wit ..sarcasm you get it all from me..
PNL is offline
Old 28-03-2007   #5
minimad99's Avatar
Trader Rating: (0)
minimad99 has donated! United Kingdom
This had never even crossed my mind and don't think it's been mentioned much before
Has anyone that has lowered had any symptoms of hitting the bumpstops, can't say i have even with 4 up.
3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads
RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE
minimad99 is offline
Old 31-03-2007   #6
Morty Mort's Avatar
Trader Rating: (1)
I'll try phoning Eibach as the don't seem to find replying to e-mails very interresting. As I now have bought the Pro Dampers (as a pro-set with springs) they are most likely shorter, which will allow the existing bump-stops to work as they have done. If I don't get any reply from Eibach I will measure the length of the pistons when fully depressed on the OEM damper and the Eibach damper. Comressing with "muscle power" is no problem with the spring removed. If the remaining piston length are the same, this must be OK I think. Too short bump-stops are not good either...
Will let you know what I find.
Morten.
Old 31-03-2007   #7
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
Binki
dave is online now
Old 01-04-2007   #8
Morty Mort's Avatar
Trader Rating: (1)
Here's a thread from where I was riding on the rear bumpstops.
http://www.fiatforum.com/stilo/81675...owering-d.html
Which again tells me to keep the original ones, as I could get a thumb n' a half underneath the rear end of the car. I am not interresting in bump stops that doesn't stop the rear from hitting rock bottom. It is mostly the front I'm concerned about - as these were the trouble when I lowered the Uno.
Work will be done after easter holiday - late april I think. Is it called easter? When mr. Jesus himself vanished into thin air at weekend, just to return on monday. Trying to remember the lessons from school here - 20 years ago.
If I can get hold of a friend (who can handle getting dirty) I will try to make a guide to changing the shocks / springs all around. Ofcourse if I can manage loosening all bits and bolts. Have aquired an extra set of spring compressors (4 now), copper grease and WD40 etc. to make this happen.
Morten.
Old 02-04-2007   #9
Morty Mort's Avatar
Trader Rating: (1)
Originally Posted by Morty Mort View Post
I'll try phoning Eibach...
So I did, and they say that modified bumpstops are not a part of this pro system kit (as I was told by the Norwegian importer). I should not trim or cut the original bumpstops either - just remove and insert to my new set.
So that's it then. No trimming until I feel any problems.
If anyone'd like to call them, their number is +4927215110.
Morten.
Old 03-04-2007   #10
numero-uno's Avatar
Trader Rating: (0)
Just a quick thought...isn't the Schumacher stilo fitted with eibach springs, if so then maybe contact fiat for the bump stops that would be specifically designed for the lower ride height.
numero-uno is offline
Old 23-04-2007   #11
Morty Mort's Avatar
Trader Rating: (1)
All right. I've now changed the suspension to the Eibach Pro Set. 4 shocks and 4 springs. Original bump stops used.
I have taken many photos, and will present a guide in the Stilo's guide section for doing this at home. It takes some hours, it's hard work, but it's simple. Is there any interest in getting a guide for this?
Morten.
Old 23-04-2007   #12
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
There has to an interest Morten as soo many are now doing it fire away my friend
PNL is offline
Old 24-04-2007   #13
Morty Mort's Avatar
Trader Rating: (1)
Well, look what I found. This is the original one from the front schock. It actually says PUR. Strange? So Eibach was right then. But not on the rear though.
All pictures are now edited and modified to fit the eibach pro system guide, so now is the text bit. I'll propably need some days.
Morten.
Name:	pur bump stop.jpg
Old 25-04-2007   #14
Morty Mort's Avatar
Trader Rating: (1)
Guide is out.
(G) Eibach or OMP Anti-roll solutions StoneNewt Punto 8 19-06-2006 22:18
Answering The Previous Question Dr_Pepper Leisure Lounge 35 25-11-2004 15:25
(S) another bump strip question!!! Punto Power Punto 2 12-11-2004 23:55
(G) Question about Servicing Dr. Gonzo Stilo 2 06-07-2004 16:38
(T) Changing the suspension - change in ride quality? boywonder Stilo 26 10-06-2004 17:55
