| dead stilo hi team sorry ive not been on for a while , its hard to get on the comp with the wife on it all the time , any way i have a problem i put a new 600 amp battery on last night , it then started ace , this mornin it started ace stopped for 5 mins , it started ace , left it at work for 9 hours came out tonight and it is dead got on dash beep beep asr fault , security fault loose connection . not a click normal dash lights were on , i took off the batt earth lead for 5 mins , reconnected it and still nowt but every warning light was on when the ign turned on , any ideas at all , thanks in advance , dave sorry its a 1.6 52
| | #2 | |||
| The modfather |
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. | |||
| | #3 | ||
| Re: dead stilo ya not kiddin mate , its sat on a tow truck at the moment
| | #4 | ||
| Glutton for Punishment | Re: dead stilo 600amp? Whats it powering, a house? Hmm, I reckon the battery is too high a capacity and isn't being charged well enough (a JTD only takes 450amps). Either that, or there is a voltage drain (ala our 1.6). Get the battery tested. If you have no luck with the car, a 2min body computer reset should help - did with ours .
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion | ||
| | #5 | ||
| It's about GO! not SHOW! | You say the battery can deliver 600 Amps but what AH is it rated at? Why did you change the battery in the first place?
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #6 | ||
| Re: dead stilo the battery i took off was low on ampage and i kept gettin messages on the dash like coolant temp when the engine was cold , the new battery is an 075 600 amp 70 ah approx , the mechanic even put a battery pack on it and it was still dead
| | #7 | ||
| Glutton for Punishment | Re: dead stilo Ok, if the battery pack isn't helping, it could be a supply problem. Check all the wiring in the battery box - if some of it was hit/tugged when you changed the battery, this could cause it. The engine node wiring goes through here and this could be causing all your problems.
| | #8 | |||
| It's about GO! not SHOW! | Re: dead stilo
Sounds a tricky one. I'd just look for connections that might have got moved when the new battery was fitted. Does seem strange that it started fine the 1st three times though. Dealer job by the sound of it ![]() EDIT: Doing that mind reading thing again Rich
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic Last edited by Argonought; 27-03-2007 at 23:03. | |||
| | #9 | ||
| Glutton for Punishment | Re: dead stilo When you say "still dead", what do you mean? It is the electrical faults causing it not to start or is it voltage issues?
| | #10 | ||
| Re: dead stilo everything lit up like headlamps and the windows went up n down ok with just the battery on the car but when the key was turned there was not a click , after i disconnected the earth lead for 5 mins and reconnected it every light on the dash lit up permanently when the ign put on , its at an auto spark at the moment , keep ya all posted , thanks for all your help
| | #11 | ||
| Re: dead stilo its back at home now , the auto spark said it was a bad engine earth so he put a new earth lead on the engine and reset a list as long as ya arm of faults it recorded and its running again , thanks for all ya replys guys
| | #12 | ||
| It's about GO! not SHOW! | Re: dead stilo Good result - seems a common fault - need to look out for that one when changing batteries
| | #13 | ||
| Glutton for Punishment | Re: dead stilo Makes me feel happier - thats exactly what I'm doing (lead is on back order).
| | #14 | |||
| Back once again w'the... | Re: dead stilo Doesn't this problem sound exactly like that D4 connector fault? I think, the brown one in the battery tray? Maybe something to keep in mind for the next time ![]() As for the 600 Amp battery, that refers to the cold-cranking-amps that it can deliver. It's not necessarily related to the capacity in Ah., e.g. a relatively small battery can have a high CCA if the resistance of the plates is low. Gel-cells have very high current capabilities also (those jump-starter packs). There is absolutely no threat in having a battery with a higher CCA rating than necessary (I've never disagreed with Rroope before, so this is a first - hope he forgives me ) Even if the capacity (Ah) is higher, that just means that from flat, the battery may take longer to charge (so, rroope is right there, except that the alternator should be more than capable of achieving this, and even if not, an overnight charge from a battery charger will get it ready).
| | #15 | ||
| Grumpy Forum Moderator | Re: dead stilo I'd never fit a battery to a stilo under 55Ah........i'd also never fit a cheap make just not worth the hassle.
| | phazer_punto | Stilo | 20 | 25-04-2006 08:40 |
| | Legsakimbo | Stilo | 29 | 01-11-2005 19:59 |
| Who here misses Abarth engines? | Reaper | Polling Station | 27 | 21-09-2005 08:47 |
| | Roberto | Stilo | 0 | 14-07-2002 22:06 |
