| Pick a window,your leavin | Gearbox oil Is this checkable/changable at home or is it a dealer job? Just remembered it should have been done at last service
| | #2 | |||
| The modfather |
unless of course there has to be a specific amount in there in which case then you will be better draining it all out and putting fresh back in I always used to check mine every service and change the oil at 30K which means mine is now overdue
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. | |||
| | #3 | ||
| Pick a window,your leavin | Re: Gearbox oil Well mines well overdue. How would I find out if there's a specific ammount that's supposed to be in there? And the type and viscosity of oil?
| | #4 | |||
| The modfather |
| | #5 | ||
| Re: Gearbox oil Anyone got a pic or diagram of the location of the drain plug? The fill plug is easy to find, but the drain not so...
__________________ Phil Thomas Yellow Peril Then:Yellow Stilo 1.6 16V 3-door - not quite standard ![]() Now: Red Stilo Abarth Schumacher GP Prodrive | |||
| | #6 | |||
| The modfather |
but I would have thought that it would be on the diff casing as this is the lowest point on the transmission and the diff is part of the unit and fed by the same oil
| | #7 | ||
| Re: Gearbox oil Would this be done by Fiat as part of service as and when required? I've had mine since 43k and now 85kish and i've never done it myself, assumed they would.
__________________ ![]() 3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE | |||
| | #9 | ||
| Re: Gearbox oil nope its not on the diff housing, its on the front of the gearbox approx 3 inches from the bottom. The head is a Hex head (im 90 % sure its the same as the sump plug). Below it is the drain hole which is a normal 10-14mm bolt. roy
| | #10 | ||
| The modfather | Is this on a 1.6 Roy... I saw that plug on Epper and though that was a bit high to be a drain plug 3" from the bottom and wouldn't drain out any gunge that might be at the bottom of the transmission casing
| | #11 | ||
| Re: Gearbox oil Found it on the service schedule. "Check manual transmission oil" on 36k, 72k and 108k sorted, worry over
| | #14 | ||
| Re: Gearbox oil In a word NO,lol. got full dealer service history so would hope all is well. I've got no reaso to believe oil is low, my stilo drives like a dream, (touch wood) apart from suspension knocking If it aint broke don't fix it....... or undo and take apart things that work fine ! I learnt that one the hard way.
| | #15 | ||
| The modfather | So your taking on trust that they have and will check it will you pay 10 k into my bank account and I promise not to spend it
| | ts86 | Uno | 49 | 17-12-2006 17:12 |
| Instructions for oil change | Koa | Leisure Lounge | 3 | 15-04-2006 03:49 |
| | newportz | Punto | 0 | 14-03-2006 10:55 |
| | puntogreg | Punto | 2 | 25-07-2005 13:09 |
| | Gandorf | Punto | 3 | 22-02-2005 10:17 |
