The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 27-03-2007   #1
Trader Rating: (0)
Fiat stilo immobiliser fault
Hi I've got a fiat stilo 1.2 active intermmitent immoliliser fault and ECU fault according to the diagnostics man.He said to take the car to fiat.The car starts after trying for five mins.Anyone any ideas?
waddy is offline
Old 27-03-2007   #2
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: Fiat stilo immobiliser fault
Ugggghh I hate these intermittent immobiliser faults
Well the diagnostics man didn't tell you very much that you didn't already know did he
How about some fault codes?
Are you getting U1600?
Is it a keycode, ECU or aerial fault?
Is it just churning over with no sign of life then just starts?
Do you get dashboard immobiliser/ security warning?
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 27-03-2007   #3
Trader Rating: (0)
First off It churns over and after 3rd or 4th attempt it fires up.The immobiliser light goes out and it comes up ebd and bleeps.Once it runs it's ok but then when you turn off the engine the same happens again.
waddy is offline
Old 27-03-2007   #4
Deckchair5's Avatar
Trader Rating: (0)
Do you have another key? Does the same happen with that?
There are some things you can try
Name:	ignition switch aerial.JPG
The key code is picked up by this aerial around the ignition key switch, I'd check the connector there.
A lot of the Code comms have to go through the D4 connector- (see above sticky as to where that is) and again I'd check and clean that connector
99 Bravo 1.2SX
Old 27-03-2007   #5
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
If you're getting EBD faults too, it sounds like a voltage issue. Check the battery condition, D4 connector wiring, earth points in the engine bay . . .
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
(G) Benfield Motor Group Complaint about Fiat Stilo, 2002 respect Stilo 54 09-10-2006 20:15
(G) Engine Fault on Stilo 16v 1.6 Aircon 2003 cazzo_man Stilo 3 25-09-2006 23:55
Abarth Badges on None Abarths' Koa Polling Station 72 19-08-2005 14:20
