| recently replaced the brake switch,but still have the same fault lights,also just replaced a coil,garage have said fault code c1460(i think)pressure regulation does anyone know what this is?
| Whaddya mean too old? | Re: again asr,esp,abs fault Some more info would be useful Do the warnings appear just on start up or on permanently? What made you replace the brake light switch? Had any work done on brakes, bearings, ABS? If that's the right code number then C1460 =Vehicle accelerometer power circuit failure (maybe ABS sensor)
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #3 | ||
| Re: again asr,esp,abs fault replaced switch due to brake lights being stuck on,faults come on on start up and stay on,had the heater unit replaced but nothing else.no work done on brakes
| | #4 | ||
| Whaddya mean too old? | Re: again asr,esp,abs fault Ok I'd check out the ABS sensors and wiring especially as the fault code points in that area too. A few specialist garages besides Fiat garages can check out the ABS sensor circuits for malfunction. There are a few basic tests you can do, continuity and sometimes just undoing and reconnecting the sensor wiring connectors have done the trick. Ha! We can dream People have disconnected the connectors to do a circuit resistance check and found it all worked when they reconnected (ie poor contact) Also a dirty or contaminated sensor wheel will cause problems Each sensor is just held in by one bolt and it's connector is nearby in the wheel arch
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 27-03-2007 at 14:17. | ||
| | #5 | ||
| Re: again asr,esp,abs fault Hi, with regards ABS control unit, is there any need to reset it in order to clear the warning? I had removed one of the sensors from the hub. I drove off without putting it back in. There was no ABS fault initially, then a few metres down the road the ABS Faulty warning light came on. Now it is on all the time. I've put the sensor back in but can't get the fault to clear. Does it need resetting, if so how? Thanks
| | #6 | ||
| Whaddya mean too old? | Re: again asr,esp,abs fault Have you done your penance and carried out your 3 ignition restarts? Logged faults tend to stay there until 3 clear starts have been done.
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 29-03-2007 at 22:58. | ||
| | #7 | ||
| Re: again asr,esp,abs fault with regards to the 3 starts,are you saying to start ignition and turn off straight away?
| | #8 | ||
| Whaddya mean too old? | Re: again asr,esp,abs fault No, any amount of time is fine as long as the car has gone through its normal start up checks three times
| | smify999 | Stilo | 12 | 13-10-2006 18:29 |
| | cazzo_man | Stilo | 3 | 25-09-2006 23:55 |
| | braden | Stilo | 5 | 29-03-2005 13:14 |
