The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 19-03-2007   #1
Athos's Avatar
Trader Rating: (0)
Mexico
Question Head lights high beam.. help
Does any body know how to lateral align them or is it a dealer must job?
http://img407.imageshack.us/img407/9811/michaelgf3tz3hz3.jpg PERMAGRIM CLUB
Athos is offline
Old 19-03-2007   #2
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: Head lights high beam.. help
I've been through this with mine and discovered nobody knows how to adjust them.
Take it to a good dealer.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 20-03-2007   #3
Athos's Avatar
Trader Rating: (0)
Mexico
I found a picture that shows an adjustable screw this one will allow to modify lateral alignment but maybe you have to take the bumper out:
The one marked with the number 6.
Athos is offline
Old 21-03-2007   #4
Argonought's Avatar
Trader Rating: (0)
Well spotted That and the regular plastic adjuster should provide full alignment.
But why do you want to adjust them?
On mine it turned out to be nothing more than a badly seated bulb
Old 21-03-2007   #5
Athos's Avatar
Trader Rating: (0)
Mexico
Mine is spoted trough incoming trafic!
And one is high and the other low, I will align them this weekend, but havent found yet how to align vertically other than dash button.
Athos is offline
Old 24-03-2007   #6
Trader Rating: (0)
I adjusted mine both vertically and horizontally, it's simple
If you look behind the headlamp you will see two white pins sticking out, one behind the high beam and one behind the low beam. If you want to adjust the vertical alignment, you will need to turn the pin behind the low beam with a small spanner clockwise for up and anti-clock wise for down. To adjust the Horizontal alignment turn the pin behind the high beam in the same direction as you want to go.
You need to set the car on an even surface about 20ft from a wall. Done mine myself and there perfect now
Some times it will look like the beam isn’t moving but, trust me, it is!
CaRcAzY
Navy BLue Abarth: SkyRoof, Cruise & climate Control, Rain, light and Parking sensors, 2 tone leather, Connect+, Xenons, Hi fi system Including a Fat rear bumper/spolier, twin pipes and BadBoi hyper sliver 18" MX RiMs ..........!!aBaRth PoWeR!!
!!WooooW!!
carcazy is offline
Old 24-03-2007   #7
Pick a window,your leavin
Trader Rating: (0)
ChrisMClark has donated!
What do you align it to on the wall? The bottom where it meets the ground?
ChrisMClark is offline
Old 25-03-2007   #8
Athos's Avatar
Trader Rating: (0)
Mexico
CaRcAzY
Thanks CaRcAzY, I have saw only one white stick, but the other must be there also unles they take it out in the '07 series, I will align them this sunday.
Athos is offline
Old 25-03-2007   #9
Argonought's Avatar
Trader Rating: (0)
Question Re: Head lights high beam.. help
That's a very interesting post.
So you're saying you track BOTH dipped AND main beam together
Presumably there must also be some adjustment to change main beam relative to dipped or is this simply not possible
Old 25-03-2007   #10
Trader Rating: (0)
Both the lights are aimed to gether.
CaRcAzY
!!WooooW!!
carcazy is offline
Old 25-03-2007   #11
Trader Rating: (0)
Hope this helps.
CaRcAzY
!!WooooW!!
carcazy is offline
Old 25-03-2007   #12
Trader Rating: (0)
It does indeed, thanks very much
(T) Head Gasket Repair / replacement!!! derekmcluckie Punto 8 02-08-2006 13:39
(T) After fitting a Head Gasket andyr Punto 16 17-04-2006 18:48
(G) High level Brake lights adjessop Bravo / Brava 4 04-04-2006 21:51
(G) Xeon head lights Paul Westhead Stilo 23 06-04-2005 06:25
