| rear door on multiwagon sometimes the rear door on my multiwagon refuses to unlock with remote control or key is there any other means of uinlocking it - this is becoming a pain has anybody any ideas? many thanks.
| | #2 | |||
| Re: rear door on multiwagon Use the tailgate? lol, Have a look at the main stilo section at the thread titled 'deadlocked', that may help Si
__________________ Dark Grey '03 Stilo MW Dynamic, 1.8 16v FIAT: Filled with Italian Automotive Technology!
| | #3 | ||
| Whaddya mean too old? | Re: rear door on multiwagon sometimes the rear door on my multiwagon refuses to unlock with remote control or key is there any other means of uinlocking it Do you mean a rear door or the tailgate?
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #5 | ||
| Whaddya mean too old? | Re: rear door on multiwagon "we dont use keys to open the back doors " If your key fob doesn't open the doors then you try using the key in the door to open ALL the locks so yes you do use the key to open the doors. The same with the tailgate, if the fob doesn't work, you try the key Remember Stuart's missus calling and saying "I'm locked out, the key fob won't work" To which Stuart replied "Use they key in the door, sweetness and light" That''s why i think Hawk means rear door but need to find out
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 12-03-2007 at 17:43. | ||
| | #6 | ||
| Re: rear door on multiwagon I'm having a similar problem with my m/w. tailgate wont open with the handle, but will normally open with the remote, but this failed as well yesterday, so cant get in the boot? local fiat dealers reckon i need a new handle assembly, which will need painting etc,etc at lots of kudos, any ideas please help?!!!
| | #7 | ||||||
Si
| | #8 | ||
| Re: rear door on multiwagon Thanks NanoSi, checked that and it was ticked unticked it and everything was ok, until today where its still unticked but only way to get into boot is with remote, nothing happens with the handle? and sometimes it doesnt work with the remote either
| | #9 | |||
| Re: rear door on multiwagon Do you have the dynamic MW, if so, does the split rear tailgate still work? Si
| | #10 | ||
| Re: rear door on multiwagon yes i have split tailgate & yes it still works nearly, last year in France it failed to shut, eventually got it to shut but couldnt open any of the boot, local Fiat garage fitted a new catch but since then Wash/wipe wont work. Fiat say glass has slipped & needs to go to a Windscreen fitter! but havnt been yet, but it does open its just the wash/wipe that doesnt work
| | #11 | ||
| Re: rear door on multiwagon Is there any chance that waters got inside the tailgate and corroded the connections. If the glass has slipped has it left a gap? or broken a seal? Why did the glass slip in the first place?
__________________ ![]() 3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE | |||
| | #12 | ||
| Re: rear door on multiwagon My glass slipped on my split tailgate, dealer took 3 attempts to repair it under warranty, eventually they had it rebonded into place. I had a problem with tailgate not opening, but this was due to the split glass not being latched properly. Had my mother in law foxed but I sorted it out and she was most impressed
__________________ 2003 52 Plate Stilo Multiwagon 1.9 JTD 115 Dynamic, with skyroof Connect+ SatNav, electric seats, heated seats, split opening tailgate, Xenon Gas Headlights, Sliding Rear Seats, Leather Steering Wheel with remote controls for Audio system, Cruise Control, Stability and Traction Control, Factory Alarm. Only thing missing is Leather trim and parking sensors!!!! & 2002 52 Plate Stilo 1.6 Dynamic with parking sensors, auto lights, auto wipers | |||
| | #13 | ||
| Re: rear door on multiwagon Minimad99, dont know why glass has slipped, presume from when i had problems in France, could well be corroded connectors, any idea how i get to them? cheers
| | #14 | ||
| Re: rear door on multiwagon In a word no........ sorry i've never seen a multiwagon boot door up close so don't know the panel layout. If you manage to get it open at all have a look while it's open, otherwise its gonna be a crawl through the rear seats and see if you can remove any of the plastic cover to gain some access. I assume when using the key (as a key not a keyfob) you still have to press the boot release button above numberplate?
| | #15 | ||
| Re: rear door on multiwagon Minimad, if it's a split tailgate, there is no key hole on a multiwagon, just the electomechanical release on the handle for the main tailgate or under the lip above the number plate for the split glass opening.
| | mase | Cinquecento / Seicento | 11 | 20-10-2005 12:19 |
| | danielson81 | Cinquecento / Seicento | 2 | 11-10-2005 23:33 |
| | DJ_Bucho | Cinquecento / Seicento | 19 | 14-05-2004 18:41 |
| | pugwash | Stilo | 1 | 02-05-2004 00:00 |
