The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 28-02-2007   #1
Pick a window,your leavin
Trader Rating: (0)
ChrisMClark has donated!
Stupid 19mm bolts!
So was super happy geting home from work earlier when I found my OMP discs and pads waiting for me...the bad news...I can't get the 19mm bolts out to remove the pad carrier any one know the best way to do this? I've tried a shed load of WD40 but that won't budge it either.
ChrisMClark is offline
Old 28-02-2007   #2
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
Re: Stupid 19mm bolts!
long bar, they have thread lock on, bolts should be cleaned up and new thread lock put on when you refit as well
Binki
dave is offline
Old 28-02-2007   #3
Trader Rating: (0)
Right, cheers Dave. Got the rear ones off with a normal socket handle, but I'll use my sliding wheel brace. I tried earlier, but I'll have to take the splash guard off to give me some more room.
Old 28-02-2007   #4
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: Stupid 19mm bolts!
International man of mystery
Wit ..sarcasm you get it all from me..
PNL is offline
Old 28-02-2007   #5
Trader Rating: (0)
funny f*cker
I tried using my sliding brace as I said...didn't think to put the wheel hard over to get better access... it's been a long day
ah well...try again tomorrow.
Old 28-02-2007   #6
alpinepg's Avatar
Trader Rating: (0)
Heat, and lots of it combined with a very long piece of scaffolding type pole to put over the end of your best ratchet fitted with 19mm impact drive socket. You wont find any bolt that can resist it......its the mechanical equivalent of introducing Angelina Jolie to a room of 6th form boys!!
alpinepg is offline
Old 28-02-2007   #7
Trader Rating: (0)
So do it after some heavy right foot action? Or blast it with a blowtorch?!
Old 01-03-2007   #8
Trader Rating: (0)
Then tw*t it with a hammer!!! YEAH!
Old 01-03-2007   #9
Trader Rating: (1)
And even if that dosent work - bashing stuff with hammers always makes you feel loads better
www.cruiseleics.com
www.leaguelineup.com/bluesoxbaseball
http://www2.apcyberax.co.uk/~sites/Kimberley/kurt.JPG
the boy kicked out at the world - the world kicked back, alot f00king harder
Kurt is offline
Old 01-03-2007   #10
alpinepg's Avatar
Trader Rating: (0)
Stick a blow torch on it......but the big lever is the real solution...the heat should just help stop the end of the bolt rounding off. Go to a local engineering or metal place and buy a metre of 2" steel tube (will cost you about a fiver) and stick it over the end of the ratchet. If your feeling flush you could get a proper lever bar from Ebay. This one is only 24" long but it'd probably do (it would cost you about £50 at Halfords!!!!)
http://cgi.ebay.co.uk/24-1-2-DRIVE-B...QQcmdZViewItem
alpinepg is offline
Old 01-03-2007   #11
Trader Rating: (0)
Big thanks to everyone who gave me advice on this, I just did it and slapped the new discs on. Looks sweet, I'll bed them in and then try them out properly!
Old 01-03-2007   #12
Trader Rating: (0)
chris should u really be doing ur own brakes m8?
ashy0125 is offline
Old 01-03-2007   #13
Trader Rating: (0)
Seeing as I know what I'm doing, yes
It's easy doing front brakes. The rear are a pig, but as long as you have the right kit its not too bad.
Old 02-03-2007   #14
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
Just what I could do with Thankyou
PNL is offline
Old 02-03-2007   #15
__________
dave's Avatar
Trader Rating: (10)
Binki
dave is offline
(G) longer bolts? which ones? Bushboy Cinquecento / Seicento 2 23-07-2004 05:06
