The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 26-02-2007   #1
Trader Rating: (0)
heater fans not blowing
Hi there,just wondering if anyone can help,i have a stilo abarth and suddenly my heater fans have stopped working,temp controls and everything still work fine but the heaters do not blow out?
wilko1977 is offline
Old 26-02-2007   #2
Trader Rating: (0)
Re: heater fans not blowing
Sounds like the fan unit has gone......Had the same problem a couple of months back
leelee01 is offline
Old 27-02-2007   #3
Trader Rating: (0)
is it a big job to replace the heater unit,if it is that which has gone.Where are the fuses for the blowers?
Old 27-02-2007   #4
Trader Rating: (0)
It all depends were you get it done, fiat wanted nearly 800.00 todo as the claim the dashboard has to be removed, in the end including the part i had it done for £234.00....There is a place in nottingham that does it. You would need to check your manual for were the fuses are located.
If you are interested in the place in Nottingham let me know and i'll give you the details
Lee+
leelee01 is offline
Old 28-02-2007   #5
Trader Rating: (0)
Cheers mate,bit far from me but will def ring rang round to get quotes,getting a bit of a smell in the car,any ideas?
Regards Ian
Old 28-02-2007   #6
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: heater fans not blowing
Heater fan switch is controlled by one of them resistor thingies so it may not necessarily be the fans at all also could be faulty fan switch its self or a faulty relay I would first check that you have voltage going to the fan before you go paying out on a new unit
International man of mystery
Wit ..sarcasm you get it all from me..
PNL is offline
Old 01-03-2007   #7
Trader Rating: (0)
Question Re: heater fans not blowing
have checked all resistors/fuses/relays all seem fine,is it worth checking the pollen filter.
If so,where abouts is it?
Cheers Ian
Old 01-03-2007   #8
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
Cheers Ian
Pollen filter shouldn't affect the working of the fan electrically but if you want to change it check out the stilo guides for removal and replacement [good old decks]
disclaimer-- the use of the word old in that message is used figuratively
PNL is offline
Old 04-03-2007   #9
Trader Rating: (0)
cheers for the help,had it checked in my local garage friday and confirmed it is the heater control unit,they are doing it for £150
(T) stilo heater blower, not blowing much!!! dalemultiwagon Stilo 1 06-11-2006 23:02
(G) Heater blowing hot! Slippy Cinquecento / Seicento 19 27-07-2006 21:31
(T) heater blowing hot then cold robinstall Punto 0 16-01-2006 19:39
(T) 1995 punto 1.1 heater blowing hot/cold whiggy94 Punto 6 23-11-2005 23:44
punto heater blowing fumes into car xrxr Lets Talk FIAT 5 23-09-2004 17:34
