| | #1 | |||
| Had the AA out earlier on becasuse I locked my keys in the car while the AA man was there, I got him to read the fault codes as engine fault had came up a few days ago. The codes that came up were;PO460 - Fuel level sensor A circuit PO638 - Throttle actuator contol range performance (Bank 1) I'v done a search and found that the fuel level sensor fault tends to happen when the car is run very low on fuel. I'm not entirely sure what the second code means, I think it mgiht be the throtte position sensor. Last time i had an engine fault come up I took it to the dealers and they adjusted the brake pedal switch, carried out a phonic wheel learn and throttle learn procedures, according to my receipt. I was also told that if the engine fault comes up again, I'll need a new throttle body. Is this right?
| Whaddya mean too old? | Re: Do I need a new throttle body? "I was also told that if the engine fault comes up again, I'll need a new throttle body. Is this right?" Who knows? It's flagging that there's something amiss with the throttle valve movement or feedback so it could be throttle valve, the wiring, connectors, actuator, or just be out of synch and need a throttle learning process - take your pick
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #3 | ||
| It's about GO! not SHOW! | Re: Do I need a new throttle body? Is this not another candidate for the throttle ECU update (unless the dealer's already done it) ?
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #4 | ||
| Re: Do I need a new throttle body? Did you try this? http://www.fiatforum.com/stilo-guide...rol-valve.html
__________________ Stiloman | |||
| | andyr | Punto | 1 | 15-08-2006 21:16 |
| | yellowstilo | Stilo | 1 | 06-06-2006 18:30 |
| | Tricker... | Cinquecento / Seicento | 15 | 05-03-2006 12:28 |
| Can I use the throttle body from a Bravo/Brava? | fiatritmo | Tempra | 0 | 26-02-2006 16:14 |
