| popping out | Pads touching discs Are they supposed to? I think the answer is no, but jacked the car up the other day and noticed the pads are touching the discs on both front sides, I can still move the wheels easily enough but when i spin one of the wheels and let go they stop almost straight away. Could this be the reason to me warping 2 sets of discs and a whirring noise while driving?
__________________ MR2 owner!!!!!!! | ||
| __________ | Re: Pads touching discs its normal, you only need a nats whiskers gap, warping can be from hard braking then sitting at the lights/junction with foot on the brake, the bit of disk trapped under foot pressure on the brakes, don't cool down as quick as the rest of the disk
__________________ Binki | ||
| | #3 | ||
| Brain freeze | Re: Pads touching discs If you had a big gap between pads and disks, you would get stones and stuff jammed in them, which would do a nice job of scoring the disk. Normal for a tiny bit of interference.
__________________ Stilo JTD 115 3dr Dynamic 2002 with Skyroof, 16" Alloys, in Pitti Blue. No mods........yet | ||
| | #4 | ||
| Re: Pads touching discs Also would have loads of pedal movement before the brakes started working.
__________________ Ciao - 1.6 Fiat Stilo, Konnichiwa - 2004 Mazda 6 2.0 D(137) TS. 2004 1.8 Vauxhall Vectra - 5 Door 1974 3.5 V8 Triumph Stag - 2 Door | |||
| | Italian Coke Can | Cinquecento / Seicento | 17 | 11-06-2007 15:32 |
| | kritip | Cinquecento / Seicento | 28 | 19-10-2006 19:10 |
| pads and discs | lanciak69 | Ulysse | 4 | 30-09-2005 09:45 |
| New discs and pads | seo | Lets Talk FIAT | 12 | 26-09-2004 23:29 |
