The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 07-02-2007   #1
Mr.AFC
gregoreo425's Avatar
Trader Rating: (0)
gregoreo425 has donated! United Kingdom
Alternator belt trouble...
Hi ppl,
Posted a week or so ago about changing my alternator belt on my abarth, was told can be a tricky job, but is do-able. I come to change it when the new belt arrived, and heres the the trouble starts...
My dad, Brother and I set about taking the front wheel off, along with the cover plates to gain access to the Alternator belt, took off the Air Con belt, which was a piece of cake. When we got to the alternator belt, the only way of removing it was to cut it, which we did then went to put the new belt on. After half an hour of struggling, it was only when we had a look that the belt that came off read 4pk 668 and the replacement belt read 4pk 643, bastard we thought, sent us the wrong belt, so phoned them up to be told that the 643 is actually the belt listed as the correct one, phoned up a couple of other places too and been told the same thing. Anyone got any idea why i had a 668 on? Now i no what ya thinking, just replace it with another 668, have tried, but is nowhere as tight as it should be. Would be cool if someother abarth owners could have a look or know what belt is on theirs.
Gregg
Next Projects...
Lowering 35mm
Alloys
De-badge
gregoreo425 is offline
Old 07-02-2007   #2
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: Alternator belt trouble...
I think you're on your own with this one. I've had the same experience before though (but on a different car) where the belt supplied is correct as per the catalog but for some reason it's wildly different length from the belt that's on there.
If you take the original belt to any parts store they'll be able to supply you with a direct replacement of the same size and number of grooves as the original without having to worry about belt numbers.
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
computer trouble!!!!!!!! beau Computing 108 13-06-2006 21:36
if pulled could I be in trouble sammiboo Leisure Lounge 37 06-02-2006 23:22
(T) Trouble at mill Firewarrior Cinquecento / Seicento 1 01-01-2006 23:44
i think i may have carb trouble too murcielagoGTR X1/9 0 29-12-2005 02:04
(G) Radio Trouble/ AND sunroof question?? STILO IRELAND Stilo 4 05-08-2004 21:39
